The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
sm0ky2
Take a disk magnet, diametrically magnetized
and place it on the shaft of a dc motor slightly smaller than the magnet.
aligned with the coils
when you drive the coil, the energy gets recycled by the greater combined field.
A short pulse can result in extremely long run times (few hundred microseconds=2 mins)
as it slowly winds down
Nothing useful will be drawn from it during wind down
But the demonstration shows that the energy that ran first through it
can be converted into flux and back to current through the motor again and again
until the losses consume it.
forest
Quote from: sm0ky2 on January 04, 2018, 10:26:41 PM
This is important - show us video ! Actually generators run on positive feedback, not by converting mechanical energy
sm0ky2
Quote from: forest on January 05, 2018, 01:58:09 AM
when you operate a dc motor with electricity it make a distinctive hum or buzz
When you mechanically turn a dc motor to generate, it incurs a particular pulsing
You can 'feel' when the coil pass the magnets as you turn the shaft
When the larger field is rotating from momentum, both of these occur simultaneously
with the wires 'open' circuit, you have flux, without current.
First time I discovered this was using a 5&1/4" floppy drive magnet
took a few yrs to realize that it was Not the complex field of these magnets
But actually Any rotating magnet, oriented properly to the coils will do this
The field just has to be larger than that created by the internal magnets
The two fields combine to form a combined field, with the coil induction
forming a feedback flux between them. It becomes like a spring
blueplanet
Quote from: Erfinder on January 05, 2018, 12:25:59 PM
my research indicates that you do have current with conventional open circuits, its value is infinitesimal, we need only figure out how to make it useful.
in my open circuit systems, I have both flux and current.....
No magnetic flux. Just current in the manner of charge movement from one place to another. And this current does not have to be from the same source because capacitor can be monopole rather than dipole.
I am talking about systems involving electrostatic waves.
(PS. CIA has declassified an article on scalar waves. This article seems to contradict some of the elements in the Maxwell's equations. )
sm0ky2
Yes in the form of capacitance charging
you can set off oscillations in an open circuit
By making/breaking contact to one end of an open wire
At that point all you would need to do is match the impedance
to form an LC with the open circuit oscillations
Essentially a radio is this.  A single wire antenna is an 'open circuit'
@blue
Magnetic flux can be demonstrated
It is short lived, as it disappears as the conductor reaches the max charge.
the magnetism only exists while the change in potential is occurring.
when the electric field is oscillating, the magnetic does the same.
At high voltages the magnetic field strength is very small
increases in conductivity at high voltages reduce inductivity
but it does still exist.
Any use of relativity theory will lead to discrepancies with maxwells work.
Because Einstein did not finish what he was doing. And left part of the equations
unhandled.
I don't think this means Maxwell was wrong, but perhaps we need more information
to make his equations fully translatable at all levels.
