Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Quote from: Jeg on January 17, 2018, 02:07:05 PM
(snip)
Hi TK ;)
Nice demonstration! Are your Tesla coils sharing the same earth ground?
Thanks. No, in that video nothing, neither the transmitter nor the two receiving coils are grounded by any wire connection. The power transfer proceeds entirely through space. When I touch the base of the 120V bulb with the little wire probe, my body provides a capacitive coupling to earth ground. This could be replaced by a wire to an earth ground for even more effectiveness but for the video I wanted to show that no wired ground is actually necessary. The 12 volt 25 watt brakelight bulb is only connected to the reducing coil around the third ("extra") receiver coil, nothing else.
AND I see that once again, someone has posted extra-wide pictures that cause posts to run off the right edge of the screen.
Zeitmaschine
endlessoceans: »This method will work in any Country which has SWER.  2nd and 3rd World usually.  Why do you think Barbosa and Leal restricted sales to their home Country only?«
Then why do you think Barbosa and Leal have filed international patents for this, if this is all a deliberate fake? What's the point in having patent protection for a phony device?
Void: »I would guess that they are probably power transistors«
If one can show me transistors connected with two wires only. There is definitely no third wire connected. But if you still prefer to go around in circles without any progress regarding this subject, I will not interfere any longer.
TinselKoala: »AND I see that once again, someone has posted extra-wide pictures«
Doesn't bother me anymore, see bottom of reply 32. At least a little progress.
Jeg
Quote from: TinselKoala on January 18, 2018, 12:05:38 AM
Just great! I wonder of what its behavior would be with more secondaries like Don Smith's arrangement!
I'll try the same with my Katcher's driver! Thanks for sharing ;)
Jeg
Hi again
Guys i need a software with the ability to calculate and draw the calculated phase shift to a power signal when i introduce specific values of frequency inductance and capacity to it. Is there something out there that can do the job and which i can download from the web??
Thanks
Void
Quote from: Zeitmaschine on January 18, 2018, 04:24:12 AM
Hi Zeitmaschine. Unless you can show a clear video screen shot where it can be confirmed that
there are definitely not three wires going to each heat sink, then that is only an
assumption on your part, just as much of what you have been saying is at best assumptions.
In that 2004 video, it seems at least possible to me that a third wire for each heat sink may be out of sight.
Also, your previous assumption that the Barbosa and Leal device obtained by Ariovaldo
was not really made by Barbosa and Leal just because what Ariovaldo found when he tore it down
doesn't fit with what you prefer to believe seems quite a far stretch. :) At any rate, much
of what you have been saying is not supported with evidence or seems to be in direct conflict
with evidence, or it makes little sense, but good luck with it. :)
All the best...
