Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
Void
Quote from: Jeg on January 18, 2018, 10:52:04 AM
Hi again
Guys i need a software with the ability to calculate and draw the calculated phase shift to a power signal when i introduce specific
values of frequency inductance and capacity to it. Is there something out there that can do the job and which i can download from the web??
Thanks
Hi Jeg. I don't know of any calculator type programs that can do that other than
maybe circuit simulator and analysis software such as Matlab Simulink, but I think it is probably expensive
and may have a big learning curve. Maybe someone here does know of a simpler and cheaper or free program or
online app which can do that sort of thing however.
It has been a long time since I did calculations like that, but I think these are the
formulas to use if it helps:
Impedance Magnitude:
Z = SQRT( R^2 + (XL − XC)^2 )
Phase Angle:
tan θ = (XL − XC) / R
​So, I think you would need to get the arctangent of tan θ to get the
phase angle from this formula.
P.S.
If they are simple RLC series and parallel configurations, see the online calculators here:
http://keisan.casio.com/exec/system/1258032708
http://keisan.casio.com/exec/system/1258032695
There are more impedance calculators for different parallel and series RLC arrangements listed in
the links list on the right hand side of the calculator page, under 'Related Calculator'.
They calculate the impedance and phase angle.
All the best...
forest
Zeitmaschine
Void: »Unless you can show a clear video screen shot where it can be confirmed that there are definitely not three wires going to each heat sink, then that is only an assumption on your part«
Likewise. Unless you can show a clear video screen shot where it can be confirmed that there are definitely transistors on those heat sinks, then that is only an assumption on your part.
Void: »just because what Ariovaldo found when he tore it down doesn't fit with what you prefer to believe seems quite a far stretch«
Talking about a far stretch, what about that stretch:
ENERGIA LIVRE - MINISTRO LOBÃO (translation of the video description): »The Minister of Mines and Energy, Edison Lobão, was in Imperatriz this Thursday (03-15-2012) to discuss political issues and, in an interview, spoke about "Universal Energy", a scientific discovery recently launched by researchers and businessmen Nilson Barbosa and Cleriston Leal. The minister says he has already spoken to the researchers and that the scientists representing the Ministry of Mines and Energy are evaluating this new technological breakthrough.«
Barbosa and Leal presented their (allegedly fake) device to Edison Lobão, the Minister of Mines and Energy. Interesting, I think Kapanadze did something alike.
THE TRUTH
They, Barbosa and Leal, can't have missed a ground loop, which connected the load simply to the grid, by accident, because the patent states clearly that they made modifications to the shorted coil, which according to the patent generates somehow the additional energy in the device. They would have noticed, if that shorted coil would have not worked the way they thought.
Then, did they fake this deliberately? What for? To present that fake device to the Minister of Mines and Energy? Or to have a reason to file five patents for nothing? And why that shorted coil that generates lots of heat unnecessarily if this is a fake? To risk to blow the mains fuse because of a short circuit? This does not add up.
I will tell you, what adds up: They presented their working device to the Ministry of Mines and Energy and then they were shut down by even that Ministry, because the device worked as claimed. In order to avoid a lot of trouble they were forced to back down and maybe also to »fake« their own device, to make it look like it was a fake right from the beginning; no one should ask further questions and forget about it. In addition, »damage containment« was arranged by so-called »vested interests« in the form of hired writers, whose task is to convince people in the fora that the Barbosa-Leal device was just some sort of a curious fallacy and shit happens sometimes. This is, what adds up. Sorry about that.
CONTINUING WITH THE AGENDA
cosmoLV on March 09, 2012, 03:12 AM: »Most important thing is to generate sharp pulses (triggered)«
Triggered? What could that mean? We need (maybe) sharp pulses, but we do not want to use a spark gap, because it is too unreliable. So the idea could be to ask, is the transformer used by Stepanov a step-up transformer, or rather a step-down one? A step-down transformer can also generate high voltage pulses when its primary coil (actually the secondary coil in reverse) is connected to some voltage. A spark gap connected to a sinusoidal high voltage will fire at positive peak and at negative peak. But what, if we need only positive pulses or only negative pulses? The diode bridge provides positive pulses at 100Hz low voltage. Then, most likely, those impulses should be converted to negative high voltage pulses by means of a capacitor and a resistor; no transistors involved. EV Gray: »Split the positive«. And then use what? The positive or the negative?
Anyhow, we should keep it simple.
Void
Quote from: Zeitmaschine on January 18, 2018, 06:00:06 PM
Hi Zeitmaschine. But then again, I never said I was sure it is transistors.
I said my guess would be it is transistors.
I can see that such distinctions are lost on you however... ;D
All the best...
