Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
ramset
Just a quick update on the Fernandez Feb 9 2018 manifesto  investigation, discussions are underway [post 261 in this thread  http://overunity.com/17535/kapanadze-stepanov-barbosa-leal-and-the-secret-of-free-energy/255/
should have some schematics for consideration and discussion later next week
[in a dedicated thread not this one]
Chet K
Thanks Grandma
Fernandez
Keep it simple.
Look at the below image, this is how the team started. Here you see two coils over some iron in a C-Clamp. We create a completely closed magnetic field for this resonator (like most others have also). Those coils are not special, they are just coils off solenoid valves (24volts) each is about 340 Ohms. (they are disconnected in this pic) Missing is my Lenz coil, But with this setup one coil must be magnetically HIGH while the other is at Magnetically (or close to it) LOW. Overlooked in my last post was the phrase Rectified Magnetic Field, thats what you need to create and that is what creates the power in all these devices. This is a huge field, much larger then the parts that created it. In the pic I show you 2 of 3 coils that create this field.
These coils are operated in a similar fashion as a capacitor run motor. The one difference is we are not using pure A/C but rectified A/C (unfiltered) because if you use a smoothing cap you flat-line (no pun intended).
Let me tell you this, you will never produce power by looking at voltage waves. Draw out the magnetic field lines because you need them to produce power.
Are you aware one of the larger Barbosa & Leal devices requires 2000 watt input? It produces a huge output but what do you think they are doing with a 2000 watt input...... driving a Tesla coil???? nope .....they are creating a Rectified Magnetic Field.
Zeitmaschine
Any progress with your »Rectified Magnetic Field« and your »Lenz coil« yet?
Wouldn't it be an idea to use a three-phase transformer, which comprises  - no wonder - three coils and also creates a completely closed magnetic field, instead of an odd "C-Clamp"? I don't think Kapanadze, Stepanov, Barbosa-Leal started their experiments with such a clamp. But anyway I still can't see how three simple coils in a closed magnetic field can ever generate an AC ground current like seen in the Kapanadze video, or even a DC(!) ground current like seen in a Stepanov video, and thereby an output power of some KW out of nothing.
I have tried already nearly all conceivable (and inconceivable) combinations of coils, capacitors, diodes and frequency doublers, with and without high voltage, so far all to no avail; and I'm afraid that state of affairs will not change any time soon.
ramset, what about your »schematics for consideration and discussion later next week«?
ramset
  Zeitmaschine
had some issues here this last month with a member  attacking and causing problems
people really don't want to do work here with things like that going on.
been resolved now .
a bit behind on projects ATM
but definitely being discussed ,...building this "resonator "
There was a question on Current flow in one schematic previously posted By Fernandez in an older
post ,
hopefully can get back on track here..
will keep you posted
Chet
Thanks Grandma
Zeitmaschine
It appears to me, as if there is a major problem with that rectified magnetic field and the circumvention of Lenz's law, although it sounded quite easy to do a few pages ago - or am I just slow of comprehension?
Would be an idea perhaps (in order to cause general amusement) to create a compilation of some red flags I've encountered in course of time regarding free energy demonstrations. Fortunately, there is also one scientifically confirmed green flag about energy from space, not very useful so far, but should be better than nothing.
