Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
NRamaswami
We have also checked a concept similar to Thane Heins concept. It just does not work.
The dummy secondary coil works but the Tertiary that has no direct connection to the primary just does not work. I have spent money and four man days and found it to be waste.
To the contrary if the primary is surrounded by two secondaries one inside the primary and one outside both of them work and the efficiency is very close to 100%. But the output is not sufficient for us to say that the system can be made to run on its own.
These are things that can be verified by any one easily.
Tynoo
Translation Barbosa/Leal videos
- https://www.youtube.com/watch?v=99aikDvhgtA
and  outhers....
-They discovered a new natural source of energy .
- Principle of operation of the equipment is electromagnetism .
- "energy supplied by the earth's electromagnetic field, that you can get instantly to do   work, the occurrence occurs through the interaction of the electric field forces ;electromagnetic and gravitational.
-The device produces an electromagnetic field, powered by the electricity company, the captor is connected between the home power and the earth grid; resulting in a high power current .
- Go against the laws of Lenz.
- They show 3 devices, the small one - input 21 W and output 6000W with only earth wire .
The first one supply the second .
Tynoo
forest
Quote from: Tynoo on May 04, 2018, 01:17:26 PM
and  outhers....
Tynoo
Where is translated video ?
Tynoo
They talk very little about how the captor works !!!!!
Some Brazilian replicators speak more in-depth.Start by the device with only transformer.
The core tranformer is solid and non-laminated iron.
Their  system is the spin-off from Tesla transformer method. By applying special EMF force on the closed loop we give them a small kick time after time they move along the surface gaining speed. when there is plenty of them they find a better way to dissipate their kinetic energy through the load to ground where they become dormant again.
I'm personally interested and I'm going replication the device.
tomd
Quote from: ramset on February 25, 2018, 10:48:45 AM
Just a quick update on the Fernandez Feb 9 2018 manifesto  investigation, discussions are underway [post 261 in this thread  http://overunity.com/17535/kapanadze-stepanov-barbosa-leal-and-the-secret-of-free-energy/255/
should have some schematics for consideration and discussion later next week
[in a dedicated thread not this one]
Chet K
Did anything ever come of this?
It seems we have a closed magnetic circuit with two primary coils and one secondary coil wound on it. The primary coils are wound such that unlike poles are adjacent. Both primary coils are using rectified AC and the current in one coil is phase shifted by 90 degrees to the other coil. This video explains how to accomplish the phase shift:-https://www.youtube.com/watch?v=pbg_PF6MTwY
This would result in an interplay of the magnetic fields where one is increasing to its peak value while at the same time the other is decreasing to zero. What would be the effect of the magnetic fields on a secondary coil? bemf?
The points that are unique to this transformer are:-
1. Two primaries positioned with N/S poles adjacent.
2.  Current is 90 degrees phase shifted in one of the primaries.
3. Quote "phrase Rectified Magnetic Field, thats what you need to create and that is what creates the power in all these devices"
Note: Fernandez makes no mention of the circuit having to be in resonance.
If anybody is familiar with magnetic simulation software? It would be interesting to get a visual on the magnetic fields created.
This is in the same vein:- https://www.youtube.com/watch?v=4p9feKmnPNU
