Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
cheappower2012
In the green box there isn't enough shots at the right angles to show that it isn't fake.
In the 2004 video there is a coffee can hooked to a orange coil of wire,the orange wire along with another wire form the output
the spark is simply to fool the observer that its a Tesla invention.The coils discharge across the orange coil creates a series of high level pulses,mixed with the 50hz 220vac,creating a condition where,it makes reading a voltage hard to do.It also creates a fake current reading in the green box video using the clampmeter he used.The orange coil as well as all the other coils used in all of Kapanadzes
video's are a part of the device,current is created in the coil,its simply a coil,it make no difference as to how its wound only the length
is important,longer length more energy.In one device he uses three coils that are simply coils,its a 3 phase device so requires one coil for each phase.Kapanadze's device amplifies current,amplifying voltage is nonsense,if you define current as the the number of electrons effected,where voltage is the force applied it makes sense.The tpu is basically a variation of Kapandaze's device,the difference is its a series of pulses of high current,a bifilar coil is used it serves the same purpose as the coil in kapanadze's device,however its grounded,so most of the energy is lost as heat,the secondary of the bifilar coil has a diode and a capacitor,this outputs dc voltage to a load.These high energy pulses creates a mechanical effect,a vibration its not caused by a magnetic field,when a coil is wound and subjected to current pulses
it feels like a mechanical effect.In this video theres high current pulses at about 20 to 30 pulses a second applied to a coil, the tapping
noise is an unknown effect,its said to be a slamming of electrons on copper atoms,it happens along the wire at every point.
This is not a magnetic effect,it fits well with the description of the tpu feeling like a mechanical device yet made of wires.
In the Kapandaze device you are amplifying ac current,where in the tpu you are amplifying current pulses.We have to remember that Jack Durban saw the big tpu and played with it,he is an electronic engineer,so if the vibration was merely an ordinary effect of magnetic fields
he would have figured it very quickly,he had no clue.Because speculation in regards to the tpu can be applied to the kapanadze device,in the tpu,the strange looking toroids came from a few defective stereos that he rented out of hes business,there in a high end custom stereo,the toroids were used as filter chokes,because of the defect they had, there effective inductance was zero. In the Kapanadze device the toroid is replaced by strange green transformer,in some devices,Kapanadze would rewind the transformer in some devices,
the core is like two toroids back to back.This transformer was common in the soviet block,from 1970's to late 1980's,there was a lot of surplus transformers around.Kapanadze tinkered with the surplus transformers and accidentally created the device,as did SM tinkering with the toroids,accidentally created the tpu. here is a video showing the mechanical noise generated by the current pulses
the device creating the pulses, was created to test very large current pulses on toroids constructed like SM's,and plotting the magnetic field.Some things are speculation I look for, is it possible,In the case of Kapandaze you have ask the question why did only him come up with this device,two answers one its fake,two the main component the green transformer is only made at the time in the soviet block,it was not used in Europe or  used in the US or anywhere else,except the soviet block.In the case of the tpu I have seen the toroid in the stereo in real life in the past,in the case of the green transformer I have taken a few apart to study them.There are also a lot of clues in the aquarium 2 video.
Kapanadze is full of tricks and wants everybody to believe its a Tesla invention.
https://www.youtube.com/watch?v=wt7DoR0qtzo
Hoppy
Quote from: wattsup on January 11, 2018, 12:47:23 AM
Look, straight out you already know that my first instinct is TK faked his green box device with the bearded guy holding the feed line. That is the most logical reasoning and I already proved it above coincidence, but let's just go the extra mile and try to rationalize his device for what it is as far as we can ascertain from the visible evidence, the visible and measured data and let's just give the bearded guy a few days rest.
wattsup
Even more speculation!  That TK had a hidden power supply and a lot of eye candy is to me beyond question. That does not mean that I'm also convinced that his contraptions were necessarily out and out deliberate fakes. Its possible that he genuinely believed he had discovered a special power amplifying effect that he could not explain as technically conventional and could cash-in on. Bringing real investors to his garden demos and not letting them use anything more than clamp meters and seeing anything more than the contraption boxes at a safe distance with a good chat line was a nonsense. That TK believed he could convince real investors in this way indicates that he is either delusional, or just a con man simply hoping to find a naive investor willing to shell out loads of money on the basis of what amounted to nothing really more than a visual inspection. His demos and conduct do nothing to convince me in any way that he is a man with devices that could change the course of the world.
We have a few years to go round and round in pain in the ass discussions about his various contraptions and speculation is all we have had and can ever have about them. TK has delivered us a very big Pandora's Box!
AlienGrey
Quote from: Hoppy on January 11, 2018, 04:31:20 AM
Yes it's all very amusing points to consider you mention hidden batterys if he had one in his device it would not have had the capacity to deliver that kind of power for that long a duration and would have exploded.
Another point is you have talked about spark gaps being hidden candy, high voltage and frequency accelerates (agitates ) the electrons. Come on you can do better than that !
Some other points that face a buyer once he has it and markets it any buyer with a brain has another problem forgery by copy it's not secure.
Over to you ;)
Hoppy
Not hidden batteries Alien. As per discussions way back concluded, not the capacity as you and others have pointed out. The power would have to be from the grid or more likely a remote generator, as these must be plentiful in TK's neck of the woods. I mentioned the grenade coil as being likely eye candy. The spark gap may not be.
AlienGrey
Quote from: Hoppy on January 11, 2018, 05:30:30 AM
It's a problem of a sad fact on here that magnifying and accelerating electrons happens and has been suppressed considerably in a good many of this threads and a good many people on here are of novice caliber who need to learn quick.
Suppose we take the dally push pull module and feed it into a caducious coil both primary's do you think we might get a standing wave out of the two ends all ready set up ? that's just one idea, so now acceleration is not so much a fair ground miniature  skelter castle or pie in the sky is it ?
