Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
PolaczekCebulaczek
Quote from: Void on January 15, 2018, 12:55:38 PM
It's interesting. Regarding 'The Genesis Project', does anyone know who wrote the document
and who built the devices shown in the document? Who were those people and where are they now?
From the pictures in the document it is hard to tell whether there is anything unusual going on there
or not as they provided no details about input power and output power, and really no details at all
about how it was being powered.
Throwing around ideas and speculation can only take you so far (which is usually not very far at all when
it comes to the topic of OU), but has anyone built any test circuits which they think actually show some
interesting or promising results based on their ideas? That's what really matters IMO.  :)
If a person can't back up what they are suggesting with at least some sort of basic test setup, then what
have they really got? Just words... ;)
All the best...
genesis requires big charge on electrostatic part,  I dont know how to suck electrons from electrostatic terminal, tried with flyback but its not enough, we can also use coax shielding as charged capacitance, if this is real than creating resonance in resonance is possible AND it would be  a self adjusting resonance, here the famous tesla "extra coil"  can be wound as bifilar non inductive coil.
Zeitmaschine
Jeg: »does anyone know where to find a transformer 220 to 2000V except of MOTS which consume one ton of wattage?«
That question is interesting. Seems this is not so easy as it looks. Try combining some small 230V to 24V transformers, then connect them in reverse. Blue and Red is the input and is connected to the frequency doubler. If the capacitor resonates with the combined transformers then the output should be around 2 to 3 KV at 100Hz sinusoidal. The resistor of the frequency doubler is the central problem. Without it, the LC circuit can't oscillate, at the same time it shorts the diode bridge, so it gets quite hot and wastes a lot of input energy.
Maybe one has a genius idea how to get high voltage around a few kilovolts at 100HZ without any waste of energy, since just the voltage without amperes is needed.
Jeg
Quote from: Zeitmaschine on January 16, 2018, 08:10:18 AM
Recently i connected 220V to a 24V secondary and after seeing smoke i understood my mistake. 24V secondary needs 24V as an input and not 220V. Or else severe current will destroy the varnish of the wires due to heat.
Do you mean 10 transformers primaries and secondaries in series? Ahh now i understood what is in the pic above. Thanks a lot. I find it α very nice idea. Does anyone know what kind of transformers are they?
Zeitmaschine
The frequency doubler circuit does not necessarily provide 220V.  Here each transformer generates around 280V out, that multiplied by 8 makes 2240V at 100Hz. Input on each 24V coil around 40V. Always two 24V coils are connected in series, that makes 80V coming from the frequency doubler circuit.
Jeg
Thanks Zeit.
Looks that resistor's size depends on cap's value. Cap needs to be discharged before next cycle or else will block dc from diodes.
