Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
QuoteIngvar: take the scheme of the coach without condors and connect it to the power supply to the bridge key where + and -. The coil of the coach will be the resonator.  The key in the bridge should work with the frequency KACHERA !!!  A bifilar is placed near the coil of the caterpillar.
Got that? Simple.
Fernandez
Quote from: Zeitmaschine on February 04, 2018, 08:30:11 AM
THE ETERNAL HOAX
One way or the other, it would be generally beneficial if we could get this to work. Because if we keep failing, then this means we are entitled to call Kapanadze, Stepanov, Barbosa and Leal, Mark, Gray, Smith, Moray, Methernitha (even Tesla?) fakers and hoaxer on the behalf of the government.
Your not entitled to call anyone anything. All of you are guilty of applying traditional thinking to a device that doesn't work in traditional ways.
So it would be very pleasant for all sides if we could avoid this problem somehow (by success). It is simply not possible that after decades there is not one successful replication of any of those claims if they are real. Also it would be strange, at least, if these are hoaxes and they would have contrived all these hoaxes independently on their own accord. I cannot see any reason, why one should go through the length of such costly fakery without having a solid cause, namely an order from someone above to do it in such a coordinated manner.
Ok, look stop thinking about PRIMARY and SECONDARY. It just doesn't work like that. Forget the secondary its just a coil to remove energy THAT'S ALL. Also forget funky coil winding like bifiler...etc.
You need to build a resonator, start with iron, cut a tire iron into a straight piece, using a C-Clamp will close the magnetic circuit. Thats cheap and easy. There are two primary coils, A/C input or pulsed will be ok. Also its 1/2 wave each coil (PRIMARY) Get that iron moving, can you get it to vibrate real fast? or can you get the energy to chase its tail?  How hot can you get it with low power?
Of course a secondary coil is used to remove energy BUT you need to collect it first so forget the secondary and build a resonator.
Good Luck.
Zeitmaschine
Fernandez: »Your not entitled to call anyone anything.«
Sure. But Kapanadze and others are entitled to give us (and the whole world) the run-around? Think about that.
Fernandez: »Of course a secondary coil is used to remove energy BUT you need to collect it first so forget the secondary and build a resonator.«
Like this? Does the aquarium wiring of the three-phase transformer look familiar when compared with the second schematic above? Drawing from page 873.
If both 0.5 Ohm coils are low voltage then the 88 and 80 Ohm coils are high voltage connected in parallel and one side to ground. The 78 Ohm coil (third transformer) is not needed, thus not connected. Is one 0.5 Ohm coil connected to the frequency doubler circuit and the other 0.5 Ohm coil to the load? Since that device is not connected to grid or inverter, the frequency is unknown. It could be 200 and 400Hz instead of 50 and 100Hz. So, is this all hidden in plain view? Are we closer now than ever and we can end that nonsense game soon?
Hoppy
There will always be nagging doubts about the authenticity of the Aqua device with the shot below showing the silver braided ground wire connected (under insulation) to a copper braided wire and a second yellowish coloured wire. The silver braid is not a solid conventional braided earth strap, its a hollow but flattened tubular braid.
AlienGrey
Quote from: Hoppy on February 05, 2018, 04:52:56 AM
Looks a right birds nest! haven't you fathomed out how it works yet ? he has don it like that so any viewer cant get any where with it and if any one did  and you paid
for it you would never get your investment back. a bit of a white elephant.
The Daily device must work different totally to that idea with the way its shown, if it works at all.  ;D ;D ;D ;D ;D ;D
