Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
NRamaswami
I have seen that a spark coming from a Tesla Coil or Oudin Coil secondary if made to impact on a thick conductor is able to induce significant current in the conductor. I once used a Tester to ascertain if the current is indeed present or not and the Tester glowed as if it is measuring 100 amps.
I think that a high voltage and high frequency spark hitting two different materials can induce high current in the receiving conductor. But how it can happen is beyond my knowledge. I intend to soon demonstrate it on video and put it up. But this is not new.
In Chapter 5 page 62 of of PJK book.. the following is written
"Tesla's experiments suggest that a method of extracting free-energy is to use a Tesla coil which has a metal spike
instead of the more common metal sphere at the end of the 'secondary' coil. If the Tesla coil is fed with
sufficiently short uni-directional pulses and the 'secondary' coil pointed at a metal plate, then it should be possible
to draw off serious levels of power from the metal plate, just as Tesla discovered. This has been confirmed by
Don Smith who uses two metal plates separated by a layer of plastic dielectric, forming a capacitor. He states
that a well designed Tesla coil is capable of producing currents as high as the voltages and he demonstrates a
hand-held 28 watt Tesla Coil played on the first plate producing a substantial continuous spark discharge between
the second plate and ground. I estimate that the spark produced would have to be thousands of volts at a
significant current, which puts it in the kilowatt range, like most of Don's other devices. Video:
http://www.metacafe.com/watch/2820531/don_smith_free_energy/ Don's patent is in Chapter 3 and his .pdf
document here: http://www.free-energy-info.tuks.nl/Smith.pdf in which he explains many of his high-power
designs." See http://www.free-energy-info.com/Chapter5.pdf
I have done this experiment and what I found is that the Tesla coil secondary when made to impact on a Tester rod creates the impression of a lot of current flowing through the Tester. Since it is high frequency high voltage the frequency jumps to the ground even if it is not connected to the ground.
When I tested the coil was of copper and the receiver was steel. So the high frequency high voltage spark coming from one metal and hitting a different metal seems to be necessary for the higher output than input to mainfest. But it is only an observation made by us.
norman6538
  Thank you NRamaswami for your post. It sure is related. I look forward to your
video.
Norman
NRamaswami
I will post within a week. I need my electrical Engineer to come to operate these high voltage machines.
I have used the type of coil called Oudin coil in the experiment I described. The high voltage high frequency circuit is the same. The difference is that in Tesla coil primary and secondary is wound in contra rotating directions. In Oudin coil the direction of rotation is same. In Tesla coil there is no possibility of current or amperage coming out of secondary. In Oudin coil micro amps of current can come out but being very high frequency it is harmless any way.
You can google for Ramaswami Natarajan wireless Electricity test to see a test we recorded a year back. It is in YouTube. I am unable to post the link from my phone. The aerial in this case was one for multiple wave oscillator. But that was not properly built and we now built a proper aerial. It is a working MWO. Only now I got to know that it can be built much cheaper.
rakarskiy
I wonder who bought the drawings of the generator Kapanadze?
http://birukov.biz/index.php?t=prodaetsya-generator-tariyelya-kapanadze&id=66
QuoteGenerator free energy (BTG) Tariyel Kapanadze. The output power of the generator to 3 kW. Voltage 240 V 50 Hz. Starting from the battery, then the battery is disconnected, and the generator operates in standalone mode indefinitely.
Guide for the assembly of the generator with his hands and head
Science teaches us that perpetual motion does not exist. Many people believe this, but not all. A decade ago a simple architect Kapanadze wiped his nose set of academics from physics and in fact raised a wave of BTG-building, inspiring smart people on their own experiments.
Over the years, Kapanadze has become a classic in the field of free energy. He has implemented numerous designs of generators using the same principle of cost-free gain of electrostatics low frequency magnetic field. The magnetic field is a modulation.
Generator Kapanadze was repeated and studied. BTG showed stable operation for a load of 2 kW (electric). Scheme absolutely working, and failure of the installation wholly replication associated with lack of understanding of the principle of operation and, accordingly, the proper setting. Tesla's words that the current through the arrester should be held only in one direction is not just a phrase, but a guide to action.
At first glance, the generator is not very convenient because it is used arrester, but as practice shows, the arrester in such constructions are much more durable and reliable semiconductors.
It is natural for the said bag you never ever buy a ready-made device. Sold description generator with detailed explanations of how to make and set the generator by hand. The scheme is simple enough, but the operation she very difficult. Notorious resonance in the resonance, which is already a decade, many people scratching their heads. What are the resonances? What are they doing? How does gain? How to protect the health at work with a generator? Knowing the answers to these questions, you make your own BTG.
By purchasing a description of the free energy Kapanadze generator, you can count on the advice of the assembly move. Sophisticated electronics in the generator does not. Ingeniously simple design, it can be repeated every electrician. If you do not like the price, go to any forum on free energy, and take any favorite scheme for free.
For gifted: description proposed design of the generator, instead of a generator. Do not think that no one except you will not come up with the idea to buy and resell for a ruble for ten. Hitromudroy such "business" every day we have not one. About ready to contact the generator Kapanadze. Phone we do not give Kapanadze because it already "got" guff lovers to profit at the expense of others.
And if you still really want ready, here's a ready-made cheap generators
