Rotationnal attraction
Started by EOW, December 28, 2017, 06:25:17 AM
EOW
@Floor: ok, I try to explain:
I need to use an attraction like gravity can do but I want to change the orientation of that attraction in the same time I deformed the device. For that, I imagined a theoretical device, I replace the gravity by a lot of springs (ok, difficult to build in practice, but my goal is to break the law of conservation of the energy), the springs have the same force: the force doesn't depend of the length of the springs like that the calculation is easier. I replace the molecules of water by little spheres (a lot sure) and I attract each sphere with a spring from the green line. The blue color is the spheres (like water). At start, the orientation is 45° (relatively to the horizontal) and at final it is at 90°. I drew a red line to symbolized the orientation of the springs. I create a pressure like gravity can do with water in a container, but I have no mass (I don't need and it is easier to calculate), and the potential energy of gravity is replaced by springs. And an empty object like a white rectangle has on it a buoyancy force, exactly like a bubble of air in water on Earth.
Do you understand where come from the forces ? I added an example with the values of the pressure at the corners of the device if the force of attraction of the springs is 1N/m² (or  m³ if you think in 3 dimensions).
It is not a cycle, just a deformation of a device from 45° to 90°.
EOW
I win the energy from the torque on the triangle and the rotation of the black arm. Something on the dot 'b' cancel the moment of the triangle, so the black arm receives a torque.
EOW
I move out the white parts and move in the blue spheres.
Low-Q
I assume that the spheres is located in a magnetic area, and that the long white rectangles are magnets.
If they are, there is a huge friction between the small spheres, so I would suggest using magnetic oil instead.
Br. Vidar
EOW
Hi Vidar,
It is a pure mechanical device, no magnetism, no gravity. Theoretical, so I don't have friction, it is just to break the law of conservation of the energy, but after, you're right, it is possible to think with magnetism.
I looked for break the law of conservation at least in theory.
My last idea to replace white parts with blue spheres is very good, because the springs lost less than the green line will win.
But do you understood how the device works ?
