Nathan Coppedge perpetual motion, real evidence
Started by NathanCoppedge, December 31, 2017, 08:52:34 PM
norman6538
Nathan in msg # 9 you said this....
"Just take a neodymium magnet and make it face an iron core with a coil around it. The flux from thew magnet goes all the way through the core. This is btw a magnetic field takes a shitload of electricity to produce. Then use like a 3V DC motor to turn a round plate with holes in it between the magnet and the core. The plate should be copper&steel&aluminium plate glued together if you can't afford galfenol. This will stop the field and let it pass to the core when ever there is a hole in the plate. You will get plenty more than to run the small motor.
At some point you will start getting a counter acting field from the core&coil that hits the magnet, but does it really matter? Make one pickup coil CW and other CCW or figure it out some other way, if it even matters"
And I made such a sandwich and did not see any reduction in flux passing through the
sandwich. Have you tried this yourself and what was your result?
So far I have not seen a true flux blocker - yes diverters but not blockers.
Even a flux reducer might give some advantage. To me the laws of nature are
pretty tight....barely a crack anywhere.
Norman
Belfior
I think it was me and not Nathan...
Just pick any type of magnetic shielding and use that
https://www.youtube.com/watch?v=14ayyu9PVSI
You don't need to totally block the flux. Altering flux will produce current
You could even use a perm magnet with South facing an iron core with a pickup coil. Then between the perm magnet and the core you have an air gap with a coil that has South facing the perm magnet. This brings us back to Kunel patent:
https://www.intalek.com/Index/Projects/Patents/DE3024814.pdf
norman6538
Belfior do  you know of anyone that has the Kunnel device working? Kunnel said that "it works but not as drawn. see if you can figure out (the correct drawing Norman )
I thought toroid might be a help....By now somebody surely would have figured this
out.
Norman
