Does the magnetic-field exist ?
Started by postingsite, February 13, 2018, 02:52:28 PM
not_a_mib
This old thread might be relevant.  http://overunity.com/2485/magnetism-without-the-magnetic-field/msg33676/#msg33676
Another approach might be to model the electric field like a fluid flow, some sort of mysteriously electrified virtue continuously oozes out of charged particles then moves away at  light speed.  When this stuff reaches another charged particle, it exerts a force on it.  Magnetic effects might just be a propagation delay effect of this electric flow.  I have not done the fancy cipherin' on this approach to see if it actually works.
postingsite
  That other thread is very advanced .
   Just noting,  that my example of a garage-door  which is counter-weighted with a weight weighing exactly the same as the garage-door,  so that raising and lowering the door is equally easy,  and the little force required would almost only depend on friction ,   theoretically you could spend all day raising and lowering a 50-story building with no effort at all .
     I wonder how  physics explains that one,  other than simply  counter-weight .
   Below is a diagram I made of designs for making a  Monopole( or close to )
postingsite
Just as I sent my previous post 1/2 an hour a ago,  I was reminded that SMOTS successfully eject the ball
   So I wonder if that would be a perfect design for a  Monopole
     - a cross,  hybrid ,   between a  donut-shaped-magnet,  and a  cone-shaped-magnet,   with the usual hollow-shaft that runs through the center of donut-shaped-magnets
    The diagram below is only a side-view( so the visible central-hollow-shaft is just a see-through effect in that diagram  )
     (  the exact proportions / ratios  would actually have to be altered in this design,  until a monopole effect is achieved  )
postingsite
Just to clarify,  that my  Monopole-Permanent-Magnet   designs,    may,   or may not be the same thing as the standard definition of a  magnetic-monopole ,    since,   I sometimes think of the standard definition of a magnetic-monopole to be like a  sphere ( like a proton ) radiating out a single field out in ALL directions,  like a proton
    Below,  is a diagram of my version of the magnetic-field of my versions of Monopole-Permanent-Magnets
    (  NOTE - In the diagram, my designs for Monopole-Permanent-Magnets do not appear,  to make it easier to see the  monopole fields,  I just show a normal  'Non-Monopole' Permanent-Magnet
postingsite
  I have three separate theories about what the   magnetic-field  may actually be :
    - the electric-field
       or
    - gravity
       or
    - scalar-waves
____  ____  ____
   My theory that  the  magnetic-field  may be  scalar-waves,  is based on my theory that  scalar-waves  occur,  EITHER,
     - when  2  electric-fields  collide against each other,
     OR,
     - when  2  electric-fields  pull against each other.
     However,   I got the idea when I read that  scalar-waves  can be generated by  crashing 2 opposing electrical-currents into each other in a single conducting-wire,  I read it on the following  website,  but can no longer find the page(  it's possible I don't remember correctly, and it may not have been on that website ) ,
              www.cheniere.org
    My theory on how scalar-waves can be generated may be different to what I read,  since my theory is based on colliding or pulling  electric-fields,  rather than actual  electric-current  in a wire.
    My theory is :
      For  Coreless-Electromagnets :
      - When 2 electric-fields  collide against each other,  they send  Pushing-Scalar-Waves( like direct-lines ) straight back into the 2 electrical wires,  which is commonly called  magnetic-repelling.
          ( in some circumstances this can generate additional electrical-current in the wires  )
      - When 2 electric-fields  pull  against each other,  they send  Pulling-Scalar-Waves( like direct-lines ) against the 2 electrical wires,  which is commonly called  magnetic-attraction
      For  Permanent-Magnets :
      - My theory for Coreless-Electromagnets also applies to  the electric-fields  from the spinning electrons in  Permanent-magnets  .
         My theory could also apply to very long distance AC current transmission,  since a possible  collision of currents resulting in scalar-waves could possibly generate surplus current,  explaining why AC is often preferred for long distance current transmission .
____  ____  ____
