170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
iflewmyown
Luc, I have just finished cleaning a 36 slot stator with a 3.625 bore and a 3 in. depth of bore. I will test with a mechanical commutator first.
Garry
gotoluc
Quote from: MichelM on March 22, 2018, 07:23:59 AM
Selon Pierre (réponse à ma question dans les commentaires de sa dernière vidéo, sur Youtube),
il y a 6 X 6 bobines sous tension.
Je vous propose de regarder cette animation que j'ai faite, selon ces indications : https://youtu.be/8moN-nDHvzU
Il faudrait que Pierre regarde cette vidéo et nous dise si cela se passe ainsi.
English
According to Pierre (answer to my question in the comments of his last video, on Youtube),
there are 6 X 6 coils energized.
I suggest you watch this animation that I made, according to these indications: https://youtu.be/8moN-nDHvzU
Pierre should watch this video and tell us if that's the way it is.
Merci MichelM d'avoir rendu cette animation très unique et intéressante de l'ordre de la commutation des bobines.
Tout semble être correct
J'espère que Pierre va le regarder et me le faire savoir
Merci d'avoir partagé
Luc
English
Thank you MichelM for making this very unique and interesting animation of the coil switching timing order.
It all looks to be correct
Hopefully Pierre will look at it and let me know
Thanks for sharing
gotoluc
Quote from: ariovaldo on March 22, 2018, 09:32:44 AM
Good morning Luc. Your windings looks like a professional grade. Good job.
Ariovaldo
français
Bonjour Luc. Vos enroulements ressemblent à une catégorie professionnelle. Bon travail.
Thanks Ariovaldo,
Glad you are still around! I was thinking about you and wondering if you're still going to be replicating this device?
Please give us an update and let us know if you have a 36 slot stator.
Kind regards
Luc
français
Merci Ariovaldo,
Content que tu sois toujours là!  je pensais à vous et je me demandais si vous alliez encore reproduire cet appareil?
S'il vous plaît nous donner une mise à jour et laissez-nous savoir si vous avez un stator de 36 fente.
Sincères amitiés
gotoluc
Quote from: iflewmyown on March 22, 2018, 09:33:42 AM
Garry
français
Luc, je viens de finir de nettoyer un stator de 36 fentes avec un alésage de 3.625 et une profondeur de 3 po. Je vais d'abord tester avec un commutateur mécanique.
Garry
That's great Garry!  glad to have you on board and testing with mechanical switching.
Please keep us updated of your progress
Kind regards
Luc
français
C'est génial Garry! heureux de vous avoir à bord et de tester avec la commutation mécanique.
Merci de nous tenir au courant de vos progrès
Sincères amitiés
tinman
Quote from: gotoluc on March 22, 2018, 08:58:50 AM
I see, I thought it was clear right from the beginning of my participation that my build cannot be considered as a replication?
So just in case anyone else thinks it's a replication let me make it clear, it's not a replication and never can be considered as a replication.
I'm building with what I have on hand and what partzman has shipped me.
This build will only be to observe the effects of coil on time overlap and a rotating magnetic field. Like I already wrote, if it does more then that's a bonus!
Can all those who do have a 36 slot stator and are building a replication, please come forward (post) or pm me to let us know someone will be building and testing a 36 slot.
Luc
français
Je vois, je pensais qu'il était clair dès le début de ma participation que ma construction ne peut pas être considérée comme une réplique?
Donc, an cas où quelqu'un d'autre pense qu'il s'agit d'une réplique, permettez-moi de le préciser, ce n'est pas une réplique et ne peut jamais être considérée comme une réplique.
Je construis avec ce que j'ai en main et ce que Partzman m'a envoyé.
Cette construction sera seulement pour observer les effets de bobine en chevauchement (overlap) et un champ magnétique tournant. Comme je l'ai déjà écrit, s'il en fait plus alors c'est un bonus!
Est-ce que tous ceux qui ont un stator 36 slot qui sont en train de construire une réplique, s'il vous plaît, venez nous faire savoir que vous tester un 36 slots.
Cordialement
Luc
You could use the wrong color wire,and some here would think it was not a replication.
You know how it go's
If it's close to what the inventor produced,and it achieves the same results as the inventor shows--it was a great replication
If you build an exact replication,and it dose not work how the inventor claim's-->you did something wrong  ::)
Brad
