170 watts in - 1600 watts out - looped - Very impressive build and video
Started by e2matrix, February 17, 2018, 01:03:05 PM
tinman
Quote from: AlienGrey on March 23, 2018, 02:00:59 AM
Oh come on if one man takes a day to a job how many  men would i need to do it in an hour ?
by sharing the load and organizing the timing !
I dont think you understand AG
36 - coils.... 36 slot stator, slot sharing is necessary to accommodate number of coils.
36 - transistors for controlling relays, 2 relays per transistor....
72 - relays....  2 per coil...
In order to complete one AC cycle,each paired relays have to switch on and off once.
We have 60 AC cycles per second(60Hz),and so each relay pair would have to switch on and off 60 times per second-->that is once every 16.6 milliseconds --not going to happen.
His relay noise should sound like the below---dose it?
https://www.youtube.com/watch?v=SVZ2P0KsLic
Watch this video of his in full screen HD.
Watch the iron filings very closely
Do they look like there jumping around at a 60Hz frequency?--no way.
How many wires should be going from the stator to the relay bank?-->36 live + 1 common at least.
Dose it look like there is 37 wires in the lume from the stator to the relay bank?--see pic below.
Also,it is a wonderful feat to achieve exact mains line frequency and voltage using mechanical relays.
Brad
cheors
36  wires from the stator : 4 x 8 pins green connectors + 1 x  8 pins connector with only 4 wires attached
No need for a common wire  with that loop.
seaad
Possible ON time to relay X? (No!)
Until someone comes up with a better relay principle (timing), that makes the relays  able to work, I'm hesitant that Pierres Contraption works giving OU as shown in the movies!
tinman
it's only to rotate the magnetic field you will not get much voltage with that there is something else that I keep secret it's like an engine that has no piston it does not start it's the same thing for the generator dz the important thing is not what we see but rather what we do not see I have seen too many people who want to take the merit in my place so my contribution will stop here now it will make you discover the rest by yourself and I can tell you that it is not won it took me nearly 2 years to find the solution rotation is only one aspect of the dz is really more complicated than that at least people will be able to learn to rotate a magnetic field but it will stop they will not get the result I had, I still have problems to settle but I think everything solve problems with the second prototype that is in manufacture I have for several months I need all over again from the beginning new circuit new coil more powerful and a brand new programming that looks pretty complicated to sequence then I wish you the best of luck for the sequel and beware of those who tries to keep the information to have it all want the information for them and does not reveal anything else I wonder why humm, when I have applied for a patent I can show you the rest of the generator dz version 2 but not before thank you.
:D
