Can someone explain how a joule ringer and joule thief works?
Started by rushi95, February 19, 2018, 01:36:23 AM
rushi95
Hi sm0ky2,
I am aware of Gravity Light Foundation that uses a similar concept of clock. But they are only able to produce light constantly for 20-30 minutes. That is the best run-time I am aware of.
And you mentioned that its possible to power a light source for a few days? Any experiments or sources that you are aware of and that you can share?
sm0ky2
The mechanism sold for use in baby grandfather clocks works the best.
and the weight pulley controls run-time by length of pulley cable.
This is a controllable variable, that can be adjusted for any desired length
of runtime. Put it on a mountain, it can run for a month to light a tent in the
valley below.
Of course it may take you an hour to wind it up, it's all relative.
The size of the motor/generator also affects things.
If you use the generator current to power a joule thief,
You can light more lights with it than direct drive.
