supersam
hey brian,
if you find a cheap used bike that has front shocks, why not just throw out the spring, you now have two, remove your strut to hold the spring, and just drill a hole in your lever to accept a axel through the front fork and the lever arm.  does this not seem like the same thing?  maybe you need a block under the haqndle bars.  but maybe not.  but at least you will be getting closer to the possible crank at the axel of the lever.  so i would call this a move in the right direction.
lol
sam
supersam
hey page 46,
that isn't a bad idea, i hadn't even thought about the spring tension of one of those little flashlights.  however small the voltage when you multiply it by eighteen, using a mehess type setup, why couldn't you keep the pendulum swinging?  great idea. i think what we need here is a few simple builders.  i just can't see why with x input being so small why y output can't close the loop in some way.
lol
sam
supersam
ramesh,
this was a simple story to get the point across that when we work together we can accomplish more than we can by ourselves!!!!
lol
sam
there are alot of people that are looking at this site that are also working on other devices that might be "overunity" if they can just find a way to jump one hurdle.  i was thinking this might be some help.
