Omnibus
Don't forget Walter Torbay was also from Argentina. His was a magnet motor, though. So, is it here we go again?
Mayo
Quote from: Merg on August 04, 2010, 02:05:32 PM
...news from veljkomilkovic.com:
Theory of Gravity Machines - Gravitational Field As a Fuel
Jovan Marjanovic -- Theory of Gravity Machines -- New Breakthrough in Physics of Two-Stage Oscillator
This work is a presentation of simple theory of using conservative gravitational field as a fuel. In order to extract energy from conservative field, gravity shield effect is necessary. With proper usage of the shield, variable gravity field should be created in part of a system. Energy can be extracted only if difference in potential exists between two poles. The logic of this theory will also be used to explain two-stage mechanical oscillator of Veljko Milkovic and areas of its improvement.
Key words: gravity machine, gravity shield, over unity, pendulum.
The complete paper can be read on the next link (PDF - 122KB):
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Theory_of_Gravity_Machines.pdf
This work is really interesting. Finally we have an explanation how gravity energy can be extracted from conservative gravitational field. I really hope that somebody will soon solve the problem with movable pivot point and make great over unity machine.
Omnibus
Just to let you know. Tried to send a pm to @cesrevolucion on youtube regarding his "Generator pendulum" but he has locked his messaging system. What else is new?
Omnibus
Too bad that fellow Jovan Marianovic isn't participating in these discussions. There maybe something in his writing but it has to be discussed more thoroughly. He, for instance, observes the fact that the pivot feels no effect of mass at the extreme points when the pendulum is attached to the lever in Milkovic's device, referring to that as gravity shield, but doesn't seem to account for the fact that all this is at the expense of energy spent.
Omnibus
Also, that Argentinean device is even more interesting but the inventor prefers to hide. That's a red flag right there.
