ltseung888
I had to admit that I did not read the 133 pages of this thread.  I thought the Physics and Mathematics was worked out since 2004 when Lee Cheung Kin and I published the Lee-Tseung Lead-out Energy Theory.
I shall summarize the understanding of the Milkovic 2 stage pendulum and why it is an efficient overunity device here again.
1.       When we pulse-push a pendulum, we lead-out or bring-in gravitational energy.  For a simple horizontal push, we can use 2 parts of horizontal energy to lead-out 1 part of gravitational energy.  I am attaching the xls file for those who want to see the equations.
2.       The best pulse-push is actually tangential.  The COP will even be higher compared with 1.5 in point 1.
3.       When we consider the two stages: pendulum as one stage and lever as another stage, we can see that there is another mechanism leading-out gravitational energy.  This mechanism is most evident in the video:  http://www.youtube.com/watch?v=gC6Qlj1Mbo8
4.       Note that the pendulum bob weight (46 pounds) is not enough to lift the Weight on the LHS (74 pounds).  The additional mechanism is the centrifugal force due to circular motion.  The centrifugal force is highest when the velocity is highest.  This occurs when the pendulum bob is at the lowest position.
5.       Now the centrifugal force plus the pendulum bob weight can be slightly more than 74 pounds and thus the LHS weight is lifted.  Work is done.  Note that the pendulum continues to swing with a lower velocity.  The centrifugal force will then be less.  The 74 pound weight will fall back with a much less opposing force.  This effectively is another mechanism of leading-out gravitational force.
6.       To repeat, we are using a 46 pound weight (Wp) plus a varying centrifugal force (Fc) to lift a 74 pound weight Wg.  The centrifugal force is a “freebee” due to the oscillation motion of the pendulum. This “freebee” force helped to lift the weight Wg.  We can assume that this “freebee” force is at least equal to 28 (74-46) pounds.
7.       To summarize, the Milkovic 2 stage pendulum has TWO mechanisms to lead-out or bring-in gravitational energy.  Thus it is more efficient than the pulse-pushed pendulum.  The pulse-pushed pendulum by itself is already overunity.  This improved 2 stage pendulum must be overunity also.  The resulting COP will be better.
That is the entire logic, physics and mathematics principle behind the Mikovic 2 stage Pendulum.  It is not a hoax.  It can be and has been replicated multiple times.  I do not replicate it myself because I already know that the pulsed oscillation can be changed to pulsed rotation for higher efficiency.  I already know that the less than USD10 FLEET can have COP >>100.
I still like the Milkovic 2 stage pendulum because it is a direct confirmation of the Lee-Tseung lead-out energy theory.  We used the single pulse-push pendulum for analysis.  We proved the existence of overunity.  We do not need to build our own prototype.  Milkovic has build many excellent prototypes independently aready.  (Note: the mathematics can be further improved.)
Milkovic is already a Server of the Divine Wine.  God Bless.
Lawrence Tseung
A humble Server of the Divine Wine
ltseung888
See the attached spreadsheet for details.
This second draft spreadsheet takes into account the comments from another physicist.  The comment was - consider just the centripetal force.  This "freebee" force is at least equal to 74 pounds.  What a Divine Revelation.  The Milkovic pendulum has been replicated successfully many times.  Here is the theory and vigorous mathematics to back it up.
Divine Wine is tasty.
ltseung888
How can we improve the Milkovic 2 stage Pendulum?
One simple improvement is to replace the swinging pendulum on the LHS with an unbalanced wheel.
With the pendulum, the rate of lead-out energy production is dependent on the period of oscillation of the pendulum.  That is determined by the length of the pendulum string.
With unbalanced wheel, we can control the rate of rotation.  The size of the device can be reduced.
The next improvement is to change the simple weight up and down movement with a shaft rotation.  Another wheel can be turned with increased torque and energy.
From the outside and viewed from the uninformed, we seem to rotate one wheel and gained more torque and energy from another wheel.  They will say that it is not possible.  Some will again use the argument of violation of the Law of Conservation of Energy.  Some may say that if the mechanism is this simple, people must have discovered it long ago.  Some may challenge me to build it.
From the Lead-out energy theory, such an improved device is logical and scientific.  The result is guaranteed.  Are there any good engineers out there???
The Divine Wine will be served by many.
ltseung888
The self-looped Milkovic 2 stage Pendulum inspired design.
Note that the rotational rate of the unbalanced wheel on the RHS can be the same as the shaft driven wheel on the LHS as discussed in my last post.
This means a simple belt or chained connection between the two wheels may be sufficient for the loop-back.  When we start the rotation by spinning the unbalanced wheel to a certain rpm, the feedback mechanism can take over.  If properly designed with little frictional loss, there will be additional energy available to generate electricity or do other useful work.  Gravitational energy will be continuously led-out or brought-in.
Simple construction!  Are there any good engineers willing to take on the challenge???
If leading-out gravitational energy is possible, leading-out magnetic energy MUST be possible.  Lead-out or Bring-in Energy Machines are theoretically and practically sound.  Amen.
Who wants to question the Divine Revelations?
Merg
here is the latest info from veljkomilkovic.com:
Veljko Milkovic Research & Development Center
VEMIRC Pendulum Lab - e-Newsletter March 30, 2012 - News & Updates
Research Progress Report: Scientific Paper
Physics of the Pendulum-Lever Energy System: A Summary of Knowledge
Recommendations for Construction and Efficiency Measuring of the Two-Stage Mechanical Oscillator
by Jovan Marjanovic, M.Sc. in Electrical Engineering
The goal of this work is to summarize the findings from previous papers along with some additional comments and also to answer two basic questions:
- How to construct an efficient Veljko Milkovic two stage oscillator
- How to measure the quotient of efficiency of the constructed oscillator.
The goal of this paper is to explain all the facts about construction and measuring in order to facilitate other people’s efforts towards a replication embodying a high efficiency quotient.
Key words: pendulum, pivot point, over unity, energy, centrifugal force.
Download link 1 (292KB):
http://www.pendulum-lever.com/docs/Jovan_Marjanovic_Recommendations_for_Construction_and_Efficiency_Measuring.pdf
Download link 2 (292KB):
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Recommendations_for_Construction_and_Efficiency_Measuring.pdf
