ltseung888
Correction to the "Bessler 2SO Unbalanced Wheel".
Weight W1 is still needed to provide the anti-clockwise moment.  In the previous diagram, W1 was missing.
The Chan Wheel has this component maintained after initial tuning.  Always good to have the actual experimental device working and confirming the theory.
ltseung888
 While we wait for the experimental results of the Chan Wheel and similar, we shall focus on the various mechanisms that can lead-out gravitational energy.
We know that:
1.    Gravitational energy can be lead-out or brought-in via a pull or push of the pendulum at the right time.  For small angles of a horizontal pull or push, two parts of horizontal energy can lead-out one part of gravitational energy.
2.    Gravitational energy can be brought-in "suddenly" in Milkovic style 2 stage oscillators.  The amount brought-in is independent of the pull or push?
3.    The Peru energy multiplier used pulsing friction as input and extracted shaft rotational torque as output.
4.    The Chas Campbell device used a low power rotational engine as input and used flywheels, pulley style belts and produced greater power to drive a higher power generator.  Are there "pulsing elements" in the set up leading out gravitational energy?
5.    The adding of an unbalanced wheel to a balanced Tong wheel made the Ting wheel generate much more output power with the same input power.
6.    If we can lead-out gravitational energy, we must be able to lead-out magnetic and electromagnetic energy.  The electromagnetic energy can be many times that from gravitational energy.  The many known pulse engines fall into this category.
In the rejected Lee-Tseung patent, there was the statement that the lead-out energy mechanism could be extended to oscillating, vibrating, rotating or flux change systems.  I am sure that the statement will be proven to be correct with additional research.
I shall suggest additional experiments that will add to our understanding of the lead-out or bring-in energy theory in the waiting period.  You are welcome to do the same.
ltseung888
Horizontal magnetic pendulum?
If we can lead-out graviational energy via pulse pushing, can we lead-out magnetic energy via pulse pushing in magnetic field?
Are we using the Electron Cloud Energy?  If so, do we need to use the Chemical Electron Cloud Energy?
Are we getting a better insight of the Pulse Motor?
Divine Revelation?
ltseung888
Pulse Motor with unbalanced flywheel to maintain pulsed rotation.  Output Energy extracted via shaft.
Ting Wheel used this mechanism.
ltseung888
Comparing the Bedini Style Pulse Motor and the 225 HP Style Pulse Motor.
The early Bedini motor used one pulse coil to provide energy to the wheel.  The goal was to use as little energy as possible.
The 225 HP Pulse Motor used large coils to provide strong magnetic fields.  That helped to lead-out or bring-in more eloectromagnetic energy.  The Tong and Ting Wheels are examples.
