ltseung888
Quote from: Bob Smith on October 28, 2014, 02:27:38 AM
Lawrence,
I respectfully invite you to listen to Eric Dollard's response to the question, "Would the ether hold energy?" at 45:05 in this video (I've cued it up)
https://www.youtube.com/watch?v=6rQik9UC7xY&feature=player_detailpage&list=UU-41VqjATdRAlN7ztX8S30A#t=2702
He basically says that the ether stores energy and momentum. Therefore, by physically pulsing an object, I believe we would be causing the ether to release some of its momentum or inertia to essentially amplify that pulse from outside the physical confines of the object's own mass.  This, I believe, explains your lead-out theory.
Bob
@Bob,
We are days away in producing the Forever Running Lead Out Energy Yuen Wheel.  I prefer to have that wheel running before commenting on the theory of others.  The Lee-Tseung Lead out energy theory using classical physics and mathematics is sufficient to explain all the detailed workings.
We do not need to introduce the concept of ether.  We just look the mathematics and physics associated with the simple pendulum under the action of a horizontal force....
ltseung888
Most parts for the Yuen Wheel have been purchased.
Need the supporting frame.  That should not take too much time.
We shall polish the presentation to include the necessary theory and the extending to other Pulse Motors.  Let it rotate continuously for two weeks before the big announcement to the World.  Two sets will be developed.  One will stay at the Office.  Another can be loaned out.
ltseung888
Have two sets of Yuen Wheels ready for testing.
Picture shows the less engineered set.  We tried to get preliminary figures and develop a "feel" for the "action".  Hope to have dedicated frame support for Yuen Wheel Testing next week.
Physicists need good engineers to back them up.
ltseung888
The Yuen Wheel in its first test was ill engineered. There was much vibration, shifting of shaft position and possible loose parts and misalignments. One part with known mismatch was the axle and the bearings.  The bearing was slightly too big.  That was because of the use of the old British system and the Metric system.  The old bicycle frames used the British system and the new bearings no longer support that system
The video is now available on Youtube with Linda as the helper.
http://youtu.be/NBnZ4aVRaxg
With a well tuned and properly engineered set up, a hard pull with two unweighted wheels should rotate for a few minutes. The present hastily tested Yuen Wheel only rotated for less than a minute and achieved only 30 turns approximately.
Much more engineering needs to be done before we can claim success.
However, we have the basic platform to start testing.  We can test
1.    Unweighted pair of wheels
2.    One unweighted Wheel A and one weight on Wheel B.
3.    One weight on Wheel A and one weight on Wheel B.
4.    Two weights on Wheel A and one weight on Wheel B
5.    Two weights on Wheel A and two weights on Wheel B
6.    Three Weights on Wheel A and two Weights on Wheel B
7.    Three Weights on Wheel A and three weights on Wheel B.
From the Lee-Tseung lead-out energy theory, every time a weight reaches the lowest position with maximum velocity, it will generate the highest centrifugal force.  That action will bring in gravitational energy.  Thus one weight represents one pulse per revolution; two weights represent two pulses per revolution etc.
For hand rotation, we believe a maximum of 6 weights is sufficient.  We can space the weights evenly in the first tests. (e.g. two weight at 180 degrees apart; three weights at 120 degrees apart; six weights at 60 degrees apart etc.)  We can calibrate carefully.
The hastily tested Yuen Wheel with six weights rotated for more than 2 minutes and over 100 turns.  The axle shifted and touched the omega bearing.  The test was stopped so that the engineers could check it out and new tests may have to be done on the better engineered set.  The Yuen Wheel may have its dedicated and firmer frame to do future testing.
There are other parameters that can be tested.  These include different diameters of wheels, different weights, more wheels, lower friction set ups etc.  However, we should have proper test results for the present set up before introducing other parameters.
The direction appears promising.  The ball is now in the court of the engineers.  May the Almighty bless them.  Amen.
ltseung888
Did the first dry run presentation last night.
Comments include:
1. The most convincing video is the Milkovic 2SO pendulum.  I looked but did not see years ago.  Now I am convinced that the lifting of the weight is from the increased clockwise moment.  The Energy is brought in from gravity.  The amplitude of swing of the pendulum did not significantly decrease.  I should have seen it years ago.
2. I like the slide on the horizontal pendulum best.  Once I accepted that gravitational energy can be lead out via the pulse pendulum, all I needed was the link to leading out magnetic and electromagnetic energy.  That slide provided the link.  It readily led to the pulse motors with large drive coils and rotating magnets.
3. I can smell the revival of the Bessler Wheel.  The video showed a failed attempt.  But it showed the importance of engineering and the need for a large wheel.  The large wheel provided the high centrifugal force to overcome friction and do extra work.  The placing of the weights is the secret.
4. Call me again after better engineering.  I shall bring the snacks for every one.
5. I do not mind contributing another HK$1,000 if you name the Wheel - Cheung Wheel - in honor of the late founder of the Hong Kong Invention Club, Mr. Cheung King Fung.  Place that Cheung Wheel in the Office of the Hong Kong Invention Club and let it rotate forever.  That will be an inspiration to all future inventors.
