0 Members and 23 Guests are viewing this topic.
@Void: The device shown in the "Chinese investors" video simply has one of the electrolytic capacitor cans gutted and the insides replaced with button cell batteries like LR74. The circuit will keep the LEDs lit brilliantly for many hours, perhaps even days, running on these cleverly hidden batteries.
Akula/Stivep/Ruslan are suffering from violation of Conservation of Miracles. They are not allowed so many! Different circuits, all "working", but only for them and for no one else. Cheap devices with just a few components, schematics posted, but for some strange reason they will _never_ send anyone we can trust, like you or me, one of their "working" models. Think about it.
Quote from: ltseung888 on November 19, 2014, 06:25:05 PM
Void,
Thank you for the good information.
I do not mind that some information is many years old.  The Milkovic 2SO must have been around for over 20 years.  Why do thousands of scientists look at it and cannot see that it is already an OU or a lead out energy device.
Simply because IT IS NOT any such thing.
I was told by a mechanical engineer that the Milkovic 2SO was one of their projects when he was an undergraduate over 10 years ago.  They, including their lecturer. did not make the link with the unbalanced wheel.
How many who looked at the video made that connection?  How many build the equivalent of the Chan Wheel?  How many confirmed that a balanced wheel cannot lift the Weight whereas the unbalanced wheel can easily lift the Weight?   How many noticed that the amplitude of oscillation of the pendulum does not decrease?  How many conclude that the energy must come in from outside?  How many realized that gravitational energy must have been brought in?
How many actually made careful measurements? How many used proper test equipment? How many performed True Experiments? Every one who DID do these things knows that the oscillations do in fact decrease and that there is no more work available for output than was put into the system in the first place.
If gravitational energy can be brought in by the unbalanced wheel Milkovic style, can magnetic or electromagnetic energy be brought in similarly?
This vital link points to the possibility that many pulse motors are actually OU.  The efforts of thousands of OU researchers will not be in vain...
If wishes were horses, Lawrence, beggars would ride. No pulse motors are actually OU, and if you would like to dispute that statement, you can just present one, using proper measurement, that you think IS. But of course your "225 HP pulse motor" is Top Secret, isn't it.
What happened to all those "OU" Joule Thief boards you sent out? What response did you get, when everyone found that they weren't OU at all and that your measurements were bad and your conclusions false?
And ... just WHERE do you get your electricity, Lawrence? Why do you not answer this simple question? I  know why... and so do you.
ltseung888
Void
Void,
Hi Lawrence. My comment that the bi-toroid transformer was around for some time was of course not meant
to suggest that something being around for some time means it is not valid, but I was just pointing out
that that device has been looked into quite a bit and does not appear to give over unity. I can't comment on
the Milkovic 2SO device or other similar types of mechanical devices because I know next to nothing about
such things. I will say this however. If any given device really is producing over unity, it shouldn't be too
overly difficult for the most part for a qualified experimenter to set up a demonstration that clearly shows
that the device is generating over unity, which can stand up to close inspection. If any given device does
really produce over unity then it should stand up to inspection by qualified technicians, engineers, and scientists, no?
I realize that many people will not even look at such devices because they have already made up their mind
that over unity is impossible, but in the case of those who are qualified and who are willing to test such a device,
if the device really is clearly producing over unity then it should stand up to such an inspection without too much difficulty.
Something to consider anyway.
The devices by Akula and Ruslan are set up to be self running, so this completely eliminates potential measurement error.
(For lower power electronic devices, the devices can be placed in a faraday cage to eliminate pickup of external EM fields.)
The only other possibility for those devices not producing over unity is (obviously) some sort of trickery.
One only needs to do some basic tests to confirm that the device self runs, and to also be able to fully disassemble such a device
to determine if there is any trickery involved. Due to wide scale skepticism about over unity, it would seem to be quite advisable
then to set up a potential over unity device to be self running if at all possible, as this eliminates potential considerations to do
with measurement error. That would seem to be the way to go in regards to presenting over unity devices to the scientific community.
There really often is so many factors that could potentially affect measurements that configuring an over unity device to be self running,
if at all possible, before making any public claims about over unity would seem to be advisable.  :)
All the best...
