Paul-R
Quote from: ltseung888 on December 14, 2014, 04:02:57 PM
The only problem is that most Pulse Wheel Researchers have not figured out "pulsing at the right time"
This is not so. if you check Patrick's book, there is an enormous amount about various people's timing discs, Hall effect switches etc to ensure precisely that.
ltseung888
Analysis of the Christmas Gift continued
4.   The mechanical engineers have been brainwashed to the concept of balance.  Any unbalanced system is considered "evil".  That is probably why they never seriously looked at the unbalanced wheel.
The flywheels have been around for decades.  They were used as energy storage devices and as devices to smooth out vibrations.  The engineers have never been taught the theory of lead-out energy.  They never know that environmental energy such as gravitational energy, magnetic, electromagnetic or electron motion, electron cloud energy can be brought into a system.  They mainly used fossil fuels (chemical energy as a subset of electron cloud energy) and polluted the environment.
Many had looked at the Milkovic 2SO.  Some universities and technical colleges even used it as student projects.  Few saw the link with the unbalanced wheel.  Almost none saw that gravitational energy was brough-in.
It is still not too late to pour resources to research into unbalanced wheels and lead out energy.  The USA and Chinese Governments had their hands on the 225 HP Pulse motors for many years...
ltseung888
Quote from: noonespecial on December 15, 2014, 07:46:22 AM
Yes, I guess my only point was that the 2SO by itself is NOT a OU device. In its simplest form, its a lever where a downward force at one end creates a lifting force at the other. The absolute best it can do is near 100% efficiency (minus pivotal frictional losses) because the formula is F x D = F x D.
Any gain greater than 100% will be realized in the transfer of energy TO the input device (bicycle wheel in your case) relative to the final output. For instance, it would interesting to see if you could drive your input wheel with a 100 watt motor and then turn a >100 watt output generator. This would silence any critics.
Best regards!
Many looked and could not see.  It is a matter of scientifically measuring the INPUT (finger push) with the OUTPUT (74 pound weight lifted twice).
Work = Force x Displacement
The Input Work = push by finger x an inch or so displacement.
The Output Work = Lifting of the 74 pound weight x more than an inch displacement.
We now can tune the Chan Wheel to get the OUTPUT work >> INPUT work.  The accurate scientific measurement will come (possibly from more than one source).  You can build a simple Chan Wheel to do the same.
You looked and did not see that the Milkovic 2SO by itself can already be an OU device. (I also looked and did not see for 10 years!) The OU comes from the lead-out or bring-in gravitational energy...
ltseung888
Quote from: Paul-R on December 15, 2014, 01:34:39 PM
You are right.  Many tried and succeeded.  However, few got the credit they deserved.  Many got discouraged by the trolls and the road block of "Conservation of Energy".  The Lead-out energy theory will remove the road block and silence the trolls...
ltseung888
5.   The Yuen Wheel consists of two or more unbalanced wheels.  Experimenting with the size of the wheel, the magnitude and number of weights on the rim of the wheel is likely to yield the Bessler Wheel which can lead out gravitational energy to rotate for 53 days and do some mechanical work.
The Yuen Wheel is interesting because it has been used to test the various parameters of the unbalanced wheel.  We experimented with the number of weights and their positions on the rim of the bicycle wheel.  We also experimented with one, two, three and four wheels on the same axle.  We shall do some experiments with two axles.
The experimental results so far suggested that the Bessler Wheel may not be a hoax.  We may indeed lead out enough gravitational energy to make the device running forever with some energy to spare.
However, we shall focus on the Chan Wheel first.  The Chan Wheel will provide the necessary scientific data to confirm the lead-out energy theory.  Once the theory is confirmed beyond any shadow of doubt, the rest will be smooth sailing.  One of the most difficult part in measuring the Input Energy of the Milkovic 2SO has been solved in the Chan Wheel.  We measured the drop in potential energy of the weight at the rim.
Some actually argued that the Milkovic 2SO itself is sufficient proof already.  However, we would like to have a working lead-out energy device in our own "laborartory".
