ltseung888
Quote from: norman6538 on January 03, 2015, 10:45:10 AM
On the slide6 drawing - what is RHS?
I made such a pendulum and got inconsistant results. I thought he said
in one direction it lifts W1 but not in the other direction.
*** You probably had a shaky setup similar to my first attempt on the Chan Wheel.
I always thought that the leverage increases when the pendulum moves
away from the fulcrum and decreases when the pendulum moves toward
the fulcrum and thus W1 goes up and down.
*** No.  Examine more carefully.  Look at the RHead100 video 6 again.  The Weight is lifted when the bob swings with maximum velocity at the lowest position.
What have others experienced in your tests?
*** Even if the Chan Wheel is not shaky, the maximum height of W1 reached may be at the second, third, forth, fifth or even sixth swing.  One possible explanation is that some gravitational energy is brought-in...
Norman
Morality point:
Believe experiments and repeat them.  If results are inconsistent, find out why...
Consider all possible explanations...
Do not blindly believe in "authorities"...
noonespecial
Quote from: ltseung888 on January 03, 2015, 06:56:48 PM
Let us look at reply 2447 again.  When the pendulum swings, the centrifugal force will cause the force pulling the spring to vary.  The weight in the middle will oscillate.  This is oscillation in the vertical direction.
(What happens at resonance?  Two frequencies match?)
If a pulled pendulum can lead-out gravitational energy, what about a pulled spring?
If a pulled spring can lead-out gravitational energy, what about the swinging lever?
In all three cases, we need to consider the potential and kinetic energy exchanges.
If oscillation in either vertical or horizontal direction can lead-out gravitational energy, how about magnetic energy?
In particular, must the energy in lifting the Weight W1 in the Milkovic 2SO be transferred from the swinging pendulum?  Will any Laws in Physics be violated if some or all of that energy comes from gravity?
Morality point:
Things may appear simple on the surface.  But dig deeper.  Apple falling from a tree is simple...
Thanks for all the helpful comments and experiments.  We are all learning...
The importance of resonance with regard to oscillation:
https://www.youtube.com/watch?v=aZNnwQ8HJHU
Bat1Robin2
This pendulum stuff is obvious to me not overunity. if you lift a weight then allow it to drop back down the energy is returning to the system no output is produced so the small push is only needed to overcome frictions. small input no output.. it is no different from 2 capacitors charging each other with a small burst of energy to keep it swinging. not overunity no output and should be common sense to everyone. they will have an very big issue attempting to loop that device.
ltseung888
Quote from: Bat1Robin2 on January 04, 2015, 12:32:40 AM
Dear Bat1Robin2,
We are not talking about the simple pendulum swinging alone here. We are talking about:
1. The pulsed pendulum leading-out gravitational energy.
2. The Milkovic 2SO leading-out additional gravitational energy in the weight lifting.
3. The need for resonance in combining 1 and 2.
4. Extending the concept to other mechanical two stage oscillation systems.
5. Extending the above to magnetic and electromagnetic systems.
6. Extending the concept of extracting energy from electron cloud or electron motion to beyond chemical reactions.
7. There is no need to burn fossil fuels to pollute the environment.
8. There is no need to use the nuclear energy of the atom.  The energy from the electrons is sufficient for all energy needs.
Morality point:
The 225 HP Pulse Motor is no hoax. The WITTS generator is no hoax.  Will the Chinese and USA Military release the technology to benefit the World???  Should the religious WITTS disclose their technology???
Many other "free energy" researchers may also be using "lead-out energy" without stating it...
Pirate88179
Quote from: ltseung888 on January 04, 2015, 02:13:10 PM
Dear Bat1Robin2,
Morality point:
The WITTS generator IS a hoax.  That is why they still pay an electric bill and have an electric meter on their property.
Lead out=0, or even -20.
