ltseung888
Quote from: noonespecial on January 12, 2015, 11:40:53 AM
Every two stage device I have built has also failed this test. The only way this could possibly be successful would be to provide some type of feedback control to maintain resonance under load.
Have you tried the experiment suggested in 2483 yet?  Make sure you do not have other iron objects close by.
ltseung888
Quote from: ltseung888 on January 12, 2015, 05:44:06 PM
Experimental result:
The stationary magnet caused the magnetic pendulum to tilt away from vertical.  Even if the number of magnets changed at either the stationary or moving magnet, we cannot produce the trampoline effect.  The best configuration is when both magnetics have only one small magnet.
http://youtu.be/NkBbjK7ED4A
Morality Point:
Some simple experiments are worth doing even if we expect the result to be negative.  We can learn even from unsuccessful experiments...
ltseung888
Conversation with Peter Chan:
Peter: "What is the next step?"
Tseung: "We can simulate the Minator Wheel again.  This time, we use Unbalanced Wheels.  If you look back at the simulation video 7 years ago, we used 8 magnets in a balanced fashion."
Peter: "I want to do something more challenging that may lead to the 5KW product."
Tseung: "You can go for the Pulse Wheel or the FLEET."
Peter: "My background is mechanical.  I shall go for the Pulse Wheel.  How should I start?"
Tseung" "Start with a single winding.  Attract and repel one single magnet on an unbalanced wheel.  Get some feel for the current, the number of turns, the angles to be used."
Peter: "What is the mistake you made with the Tong Wheel?"
Tseung: "We tried to simulate the 225 HP Pulse Motor.  We put on multiple magnets and got some promising results. We used the proximity switch because Tong was familiar with it.  We then just kept experimenting without the solid feel or knowledge."
Morality Point:
Getting some promising results without solid knowledge can be dangerous and frustrating at the end.  QEG is another example.
ltseung888
There is another approach to the gravity machine by William Skinner.
http://overunity.com/14655/1939-gravity-power-multiply-power-by-1200/#.VLd1NOk5Bjo
Gravitational energy can be lead-out or brought-in. Unbalanced Wheel and Centrifugal Force were also effectively used.  This gives more confidence to the Bessler and Yuen Wheel researchers.
The logical path is to use the more powerful magnetic and electromagnetic energies.
Morality Point:
Have an open mind.  A simple Milkovic 2SO or Chan Wheel is a lead-out energy device.  It is easy to accept that the Skinner device is another example - no need to replicate it ourselves...
