0 Members and 76 Guests are viewing this topic.
Paul-R
Quote from: ltseung888 on February 02, 2015, 10:21:41 PM
The Dr. Liang Car cylinders.
He used ICs to provide repulsion.  Exactly what does that mean?
The Cylinders can be very close together.  The magnetic repulsion is much stronger when the distance is closer (1/(r x r)).
By "IC", I take it you mean "integrated circuit".
How can an IC provide repulsion?
Does he have a patent or application? If so, what is its number?
ltseung888
Quote from: Paul-R on February 03, 2015, 09:47:13 AM
China Patent Number 01123526.8
Some IC circuit with coils???
ARMCORTEX
https://www.youtube.com/watch?v=y6q_l6FpacU
Could it be that there is some rotary flow switch that inputs a shock, then in the moment of impact, magnets turn on in successive pulse train like impacting the magnets on the inside of the aluminium ring.
His ring has offsetted holes in them to hold magnets and keep structural integrity, he has many large magnets.
The hydraulics are used to input something, in relation with, those magnets. The hydraulic system is not an energy recycling system, it is used in conjonciton with magnets, as the system driver, in an oscillator system so to speak.
How and in what situation does this apparently make this self-sustaining. This is where the lead-in theory is Lawrence Tseung falls short, it cannot help us understand things practically and lacks substance.
ltseung888
Quote from: ARMCORTEX on February 03, 2015, 06:06:02 PM
I could not pick up enough details from the video to give a judgement.  But I can make an educated guess from my experience with the Tong Wheel which questionably demonstrated Output Power greater than Input Power.
1.  The Tong Wheel was unbalanced.  The number of rotor magnets could be odd and not exactly symmetrically spaced.  We can have an Unbalanced Wheel by adding a weight.  We can also remove a section to make an Unbalanced Wheel.
2.  The coils to propel the magnets are likely to be driven by Pulsed DC.  This provides the oscillation or jumping effect to extract both gravitational and electromagnetic energy.
3.  The external flywheel stores some of the lead-out energy and helps in the self loop process. The Lee-Tseung Lead-out energy theory states that we need an oscillating, vibrating, pulse rotating or flux change mechanism to lead-out energy.  Does the device shown in the video contain such features?
I suspect the device is a variation of the Tong Wheel with the "Unbalancing" done within the rotational system.
Merg
Milkovic Pendulum replica by Konstantin Ivanov
Attempt to manufacture a "pendulum Milkovicha" from scrap parts and check the possibility of converting vibrational motions crossbar in rotation (followed by loading on the generator). Primary mayatnik- Dumbbell 3 kg, set top cargo bike frames- 3 kg.
https://www.youtube.com/watch?v=bf3B38bDZb4
