0 Members and 27 Guests are viewing this topic.
sm0ky2
I have a device that can lead out gravitational energy.
it's called An Anti-Hover Craft
You supply the initial power to lift it to the upper atmosphere,
after that it draws its energy from the lead-out gravitational effect and will self-power all the way to the earth
and increase in energy as it travels.
when it reaches the ground it will be traveling at terminal velocity and impact with tremendous force.
MarkE
Quote from: sm0ky2 on March 19, 2015, 07:05:30 PM
Has the Revolutionary Outer atmosphere Crashing Kit been featured on PESN yet?
deslomeslager
Dear Lawrence,
I happen to have a one wheel bike. I turned the right side crank 180 degrees, so both point in the same direction. Then I removed the pedals and attached a small iron weight to it. So I now have a one wheel bike (it also has a saddle of course) from which I can turn the wheel by hand. Or by rocking the bike forwards and backwards. I can get it to spin very fast that way. As soon as I stop rocking (speeding) the bike is difficult to hold with my hands, and depending on how I hold it, it may start thumping with the saddle on the ground. It looks like I am adding energy to the spinning wheel by rocking it forth and back, and I can let some of the energy get back out in another direction. I think the rotational speed will get less if energy is used to lift up the bike, thumping on the floor.
It is possibly half of an example. I assume I will need to attach the bike to something else, to use some of the energy (and to perhaps rotate the wheel by motor so we can control the speed).
I am not an engineer, and use all kind of spare parts I have or can find. I have some more bike wheels, even one with a dynamo in the hub, but I am bad in connecting all of this together. Most of the time my constructions will be to weak to support all that rocking energy. I am better of with electronics.
Please recommend how to proceed.
Pirate88179
Quote from: ltseung888 on March 19, 2015, 06:29:25 PM
Dear Electric Motor Manufacturer,
I am interested in working with you on a new technology known as QMOGEN.  QMOGEN stands for Motor and Generator Pair with self-looped energy.  The Motor first gets energy from mains and drives an unbalanced Wheel/Cylinder.  This is connected via belt and pulley to drive the Generator.  After full speed, the Generator will supply energy to the Motor.  The original Energy Source will not be needed.  The energy comes from the Lead-out energy – gravitational, magnetic or electromagnetic.
Details are in http://www.overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg442672/#msg442672
The best QMOGEN is the Tsinghua University Energy Multiplier.
Please contact me if you are interested.
Lawrence Tseung
(see reply 2953, 2826)
REPLY:
Dear Lawrence:
Thank you for your inquiry.  We have been making electric motors for over 50 years and have spent millions of dollars perfecting an efficient, balanced and dependable motor.  If we were to do as you suggest, our motors would not only be less efficient, but their life span would be greatly decreased.  Low friction and balancing are the keys to getting the highest efficiency from an electric motor design.  If we were to make our motors unbalanced, this would represent a giant step backward for us.
Thank you for taking the time to contact us.
Sincerely,
Electric Motor Manufacturer.
memoryman
Thank you for your inquiry, Mr. Tsueng.
We have been making electric motors for over 50 years and have spent millions of dollars perfecting an efficient, balanced and dependable motor.  If we were to do as you suggest, our motors would not only be less efficient, but their life span would be greatly decreased.  Low friction and balancing are the keys to getting the highest efficiency from an electric motor design.  If we were to make our motors unbalanced, this would represent a giant step backward for us. Frankly, we think that maybe such an suggestion comes from an unbalanced mind. Somewhat ironic, don't you think?
Sincerely,
Successful Electric Motor Manufacturer.
