ltseung888
Theory of the Flying Saucer.
If one has infinite energy, one can generate pulsed circular motion.  One can control the direction of the centrifugal force and thus fly in any direction.
Changing direction - even reversing direction is easy with centrifugal force.
There is no need for air to use aerodynamic forces.
Once a Nation masters lead-out energy, it will master the flying saucer.
The rumor that both USA and China already possess the Flying Saucer has theoretical grounds.
Will the Governments try to keep the top secret?  Will they pay the debunkers...
Divine wine flows...  The World will drop the Military Destructive Applications and go for peaceful Applications...
Sow seeds...
Lawrence Tseung
see reply 3038
ltseung888
Some old experiments by Forever Yuen in 2008 on Centrifugal Force.
https://www.youtube.com/watch?v=QnxDJ29iL_0
Milkovic 2SO uses centrifugal force... Chan Wheel uses it better.  Skinner Device leads-out more energy.
Pulse Wheels can produce large centrifugal force...  They not only lead-out energy but also serve as heart of the Flying Saucer.
Flying technologies:
1. Aerodynamic forces - Bernoulli's equation - pressure on the side smaller when fluid moves faster.
2. Rocket principle - action and reaction.
3. Flying Saucer - controlled, pulsed Centrifugal Force - no need for air; no need to push out material...
Lawrence Tseung
see reply 3038
Paul-R
All this talk of  flywheels reminds me of Eric Lathwaite. Also, a very interesting small square plywood board. It had motors with flywheels mounted north, south east and west, all rotating as one might imagine. The entire board is then forced to rotate and an upward thrust is a generated.
No fancy physics here, just processional forces adding up coherently. But it is an idea which deserves more development.
ltseung888
Quote from: webby1 on March 26, 2015, 10:21:43 AM
Actually Lawrence one would need to control inertia.
You can not make a change in direction at speed without destroying the occupants unless you can find, manipulate and control an inertial field.  If and when such is found then flight is rather simple and nothing else would be needed except for maybe a vessel to contain an atmosphere.
Forget human flight for now.  Just focus on Centrifugal Force leading-out energy and capable of moving around in space.
Should USA and China disclose the "top secret" to benefit humanity now?  There is no stopping any Nation pouring resources on such research.  The information in this website and this thread will be studied with scientific vigor.
Lawrence
see reply 3038
ltseung888
Quote from: Paul-R on March 26, 2015, 11:40:40 AM
I believe you are talking about information covered in:
http://www.overunity.com/5570/has-somebody-used-eric-laithwaite-s-device/#.VRVVGOlFBjo
In there, overunity energy was mentioned as well as flying.
Since this thread has already got much following, I shall continue the discussion here.
The power of Internet is that it can bring apparently unrelated pieces of information together...
More on youtube: https://www.youtube.com/watch?v=OI_HFnNTfyU
Lawrence Tseung
see reply 3038
