ltseung888
Met Mr. XYZ in Hong Kong.  He now understands the seventh design of the Flying Saucer thoroughly.  At one time he thought that the donut tube itself would rotate.  Once that was clarified, he found it easy.  Just follow KISS - faster the angular velocity, higher the Centrifugal Force.
He will spread the word to his contacts in China.  I shall encourage him to post his experience.
Divine Wine flows...
Lawrence
reply 3333
Pirate88179
Quote from: ltseung888 on May 29, 2015, 07:00:17 PM
Lawrence
reply 3333
This just in:
Mr. XYZ has been killed in the crash of an experimental flying saucer.  He attempted a 90 degree turn at over Mach 7 and pulled over 4,000 G's.  A spokesman from his insurance company said that they will no longer issue insurance policies to anyone experimenting with flying saucer technology.
ltseung888
Can any one recommend a precision control mechanism (possibly laser controlled) to:
1.  Switch on the DC current to the Driver Coil when the Permanent Magnet is in position 1.
2.  Switch off the DC current to the Driver Coil when the Permanent Magnet is in position 2.
Refer to the fifth design diagram (reply 3302)
http://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg450886/#msg450886
for details. (Position 1 was labelled Y and Position 2 was labelled X)
This control mechanism is a key element in the Flying Saucer Research...
ltseung888
Quote from: webby1 on May 30, 2015, 08:33:18 PM
The MHOP should be able to do the job for you nicely.
This was a joint effort between MileHigh and TinselKoala, and it was presented on this board.
All the details are available on this forum,, just go look for them.
http://overunity.com/13852/self-accelerating-reed-switch-magnet-spinner/#.VWvBmulFBjo
https://www.youtube.com/watch?v=zqFOIOTYt-4&index=1&list=PLml9VdOeqKa8F1PebS_EX7AX2aA_ZZtb9
I believe that you are talking about the two above pieces of information.
Can you or someone give a short summary?  Thank you;
Paul-R
Quote from: ltseung888 on May 30, 2015, 08:21:59 PM
In #3302, I take it that the ring+magnet rotates and the two coils are static. Not sure how the ring is to be held, but let's skip over that.
You need what is used in most pulse motors, Robert Adams, Charles Flynn etc (see chapter 1) and also the Bedini/Watson.
Place your Hall effect switch near Position Y so that the approaching magnet switches the device at position Y. This sends a power pulse of variable duration to the left hand coil. Use the circuit to vary the  duration of the pulse such that it switches off at position X.
Check that it is happening properly with an oscilloscope, maybe an LED in the power circuit.
