ARMCORTEX
In that document he has a simple image of a device, well it would be possible for them to simulate such a device on a 2d simulator like wm2d or algodoo.
Instead of that kid drawing, how to tell if the kinematics will really induce rotation, they can easily prove their device works, but they did not do that,
Useless document.
Merg
zoelra
The Milkovic two stage oscillator may very well be a "balanced oscillatory system".  No one has come close to feeding the output back into the system to perpetuate motion.  I'm not saying I agree with this statement, but many believe this to be true, and all tests to date seem to back this up.
In Milkovic's "Pendulum eases pumping of water" video, it appears that he is applying greater force than in his original "Mechanical Advantage of Pendulum Drive" video.  This could be due to the lifted weight (water) leaving the system and not applying backward force on the lever.  Just something to think about.
https://www.youtube.com/watch?v=Zt7iQmKtHu8
https://www.youtube.com/watch?v=jNdF8mTfu4g
turbogt16v
it is very easy to be  mistaken with ou in these types of devices.
if you study basic fizics you would see the problem very easy.
it is the same principle as the nuclear plant has.for it to run or stop you need about 2 days.
so imagine the force you need to keep it running it is very small (relatively small).
same as spinning a huge weight in circle.
but the problem is you always need the push ,and it is bigger than force taken, always .
so when you look at your huge weight that you keep pushing ,you think ,oh there is much force stored in it,but you are the one that keeps adding the force.
that is why milkovic keeps pushing the weight adding the force on and on
