kratkaforma
No other topic here on overunity does not have so much scientific conformations, and proofs
norman6538
So after 240 pages of information and we still cannot buy a Milkovic device off the shelf.
What does that say?
I still claim that there is a lack of solid measurements.
This device works similar to the oil well pump that has a rotating counter weight that
changes the leverage as it rotates so reciprocation results.
And it has been used to pump water like a hand pump. The long arm hand pumps
I remember were largely weight/leverage balanced such that all you really needed to
do was lift the water out of the top of the pump so it flows out - it did not have to lift
the entire rod and water that went down to the bottom of the well. The rest of the water column
was balanced by the long and heavy handle. So if you replaced that heavy handle with
a wooden handle it would take more work to lift all the water up and out of the pump.
So to lift a half gallon of water several feet was no big deal once the pipe was fully
primed because the foot valve often leaked and left the water down.
Did I miss something really big?
Norman
kratkaforma
Please take a look at this link https://www.youtube.com/watch?v=PwlKWcO79J0
and don't think about oil pump since this is something difference..
Oil pump does not have a pendulum, and Milkovics pendulum has specific way of working - with
scientific references and patents; Also, Milkovic made improvements with elastic pendulum.
norman6538
Quote from: kratkaforma on April 23, 2018, 06:45:13 AM
I did see that but I heard no one visited the machine nor replicated it no explain how it works.
Did you?
Norman
