FreeEnergy
Earl has a good points on this...check out the link below. he says the pendulum should be aerodynamic shaped and that the ball bearing(s) should be magnetic bearing for best results (near zero friction).
he also thinks this system won't work in a purely mechanical way and that we should apply electromagnetic coil(s). still i think we should try both ways and any other way possible. there is more details so check the link out below.
peace
http://peswiki.com/index.php/Directory:Milkovic_Two-Stage_Mechanical_Oscillator
fantasyl
Could someone suggest me a good simulation program to verify my results? Better if it's available in free trial.
I attached two spring with light tension (5kgf/m)at the lever edges, the power of only one of them (in W) is the first graph on the left, so this machine is able to put some work out while the pendulums keeps oscillating....
Tensions on the ropes would be very high.....mhhhhh.
Howewer today I bought all the needed stuff to build and verify my setup.......so soon we'll know IF and HOW the strange simulations data reflects the real world.....
Dingus Mungus
I don't have enough info to replicate your starting position... Is the sim still open? If you could please describe the starting postion and component dementions, I would like to replicate your results. The graphs are really exciting to see! I hope you had air restance turned on... You do have to turn it on each time you start a new project. Also the springs don't extract that much energy, but if you replaced them with dampeners then you could more readily extract energy from the system. If you get similar results while extracting energy then I would try physical replication. My attempts to replicate your results yeilded a sim that would self oscillate, but its a glitch not sponstanious energy... Fun to watch though, the balls bounce up and down and spin on their own.
FreeEnergy
check this out. i leave the system at equilibrium state and still the massive lever starts to pick up speed. and yes the air resistance is set to high. is it because of the horizontal track?
FreeEnergy
