0 Members and 30 Guests are viewing this topic.
Solomon111
Quote from: andrea on November 15, 2009, 04:01:16 AM
@tagor
Please read the explanation of the first video clip. We lift up ONE time the pendulum until 90 degrees ( the energy input is (m*g*h) 11 joule), then we leave it to make his work. In the second video clip you have the measure of the energy output in the opposite arm of the lever: you can read it on the right and you can see in the video.
I can't be sure that this thing works, yes, maybe all this is wrong. But, well, this experiment was made with a university book of phisics in the right hand, open on similar experiments. I've just applied the same math.
Thank you, bye
I think Andrea is on the right track!
Merg
Here is something brand new from Milkovic's Newsletter:
Dear friends,
Jovan Marjanovic, electrical engineer and chief of Laboratory Analytical Team of Two-Stage Mechanical Oscillations Research, has continuing his scientific and research work in the field of ultra effective systems and new energy technologies and now he represented his analysis of over unity electro machines and their basic principles in a new study.
Jovan Marjanovic - Basic Principles of Construction For Over Unity Electro Motors and Generators
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Basic_Principles_of_Overunity_Electro_Machines.pdf (PDF 893KB)
(If your internet browser cannot open or recognize above PDF file, right click on the link and choose "Save Link As...", "Save Target As..." or "Save Linked Content As..." option to download a file to your hard disc)
"The goal of this work is to point out some important facts in construction of over-unity electro motors and generators, where output energy of the machine is greater than the mechanical energy invested on the input side of the machine. If some of the output energy of the generator is directed to the input side of the machine then perpetual motion can be achieved or perpetuum mobile."
Nabo00o
Just skimming through the document, its great to see that he shares many of my fascinations for electricity as well  :)
Again, if I start the construction of a bigger model to create usable power, then I will probably not use the old and limited methods such as what the standard generator gives.
As mentioned earlier in this tread, and although it never got completely agreed on, the Ecklin generator is one such device which can almost completely ignore the effects of Lenz law.
Another way is creating high voltage, by using high rpm and large coils composed of thin wire.
Since many of you probably know Faraday's law and Lenz's law, you know that the drag on a generator is proportional to the 'current' generated, not the watts.
Higher voltage with little amps will create much less drag on a generator than low voltage and many amps for the same wattage.
Julian
Static energy...
Dynamic energy...
Two forms of the same.
Merg
Finally, Raymond Head posted his new videos with an "escapement" idea!
I see know what he was talking about...
Escapement for milkovic two stage oscillator
http://www.youtube.com/watch?v=ljjCXpq_QSA
Testing escapements failed
http://www.youtube.com/watch?v=cCLoCZbw9ic
Why escapements failed
http://www.youtube.com/watch?v=uQLBVAaA8L8
RHEAD100, I hope you will give us more details here?!
Russell Lee
I agree,
  If it was producing 12 TIMES the energy, a huge amount of energy could be waisted in transfering the power produced to power the initial pendulum swing and still have it work.  It wuld be tough with 2 times the power, but not 12.  Hope all goes well with this, keep trying. -Russ
Quote from: Solomon111 on November 21, 2009, 11:31:02 AM
It need more work to improve!
It is not proven 12 times more energy, it is only Milkovic itself came to unreliable results of measurements, which are not exactly confirmed.
