DreamThinkBuild
Hi Uday,
Welcome to the forum.
Wow! Great work. It is amazing the amount of power you are getting from the design. I noticed that the rubber bladder pulls in pretty strong after each pulse. Would it be possible to link two bladders together so that it creates a suction in a secondary bladder with a check valve? Maybe this would be enough to make the secondary bladder self pump the water into the system once it is initially started?
Thank you for sharing.
uday79
Quote from: DreamThinkBuild on May 03, 2011, 04:14:07 PM
Hi Uday,
Thanks for your appreciation..
My first experiments were using sequence of two bladders or balloons, where i was hoping to simulate capacitance vessels of human circulation physiology. The upper balloon acts simply like reservoir chamber and distends passively whereas the lower one is where this dynamic phenomenon is observed.. And I also tried initially to connect both ends but it did not self pump for long time and whole thing stopped...
Merg
from veljkomilkovic.com newsletter:
Dear friends,
there is a new scientific paper by Jovan Marjanovic, M.Sc. in Electrical Engineering, which represents one of the most important theoretical contributions to the physics of Veljko Milkovic's two-stage mechanical oscillator:
Jovan Marjanovic -- The Secret of Free Energy from the Pendulum
In this work, the author for the first time has identified centrifugal force as a source of over unity work under some conditions and also calculated maximal efficiency quotients of the machine.
Problems which easy can undermine over unity behavior of machine were identified and solutions were proposed.
Influence of length of pendulum and critical angle on machine efficiency were clearly explained and mathematically supported.
The complete paper can be read on the next link (PDF - 125KB):
http://www.veljkomilkovic.com/Docs/Jovan_Marjanovic_Secret_of_Free_Energy_from_Pendulum.pdf
More info:
http://www.veljkomilkovic.com/OscilacijeEng.html
rensseak
Is there already a closed loop system of this two stage oscillator?
Because he use it for pumping water he could also use it for generating compressed air. With a portion of this compressed air he can then keep going the pendulum via a pneumatic piston rod.
regards
Merg
...MagnaMoRo YouTube upadate:
Free Energy Centripetal Force
A demonstration of the extraction of hi energy centripetal force using a small input of energy.
http://www.youtube.com/watch?v=-tvlvK0U3kg
