Merg
from YouTube - user: gdez1000
New diaphram pump with (tsmo) pendulum
improved design for experiments with pumping water. More vids coming soon.
http://www.youtube.com/watch?v=_zVtK1W3yl4
Cloxxki
Quote from: ltseung888 on May 04, 2012, 06:29:16 PM
Is Divine Revelation 2 this simple?
That's a complicated way to mimic a standard balanced flywheel.
+ and -  cancel each other to = .
A loose timing band will only allow the weights to settle slightly below the averages of their axles.
There is no lead-out, whatever mystic fysics you mean with that word.
Any pulsing will be returned reduced by the heat losses from the loose band.
Build it, it takes a few pieces of wood. The wheels can subsituted to pieces of wood with an additional piece at 90º as weight.
Simple (bike) sprockets on bearings and a chain. First balance out without the off-balance weights.
I'm sure that if you attach an engine to it, you can dramatically point at it spinning. It will selfdestroy at sufficient rpm, but that's all a result of kinetic energy introduced by the engine.
Even Rhead seems to have refocussed his construction talents on more probable project using true free energy: wind and solar.
ltseung888
Quote from: Cloxxki on May 07, 2012, 08:13:24 AM
The Peru Force Magnifier did not selfdestroy.  A 1 Horse Power engine can drive a 17 Horse Power load.  Please understand the real Physics and how gravitational energy is led-out or brought-in.
The device will be built by real engineers.
johnny874
Quote from: ltseung888 on May 07, 2012, 09:06:46 AM
  If it delivers 17X the power, it most likely would be in use. It might be a variation of using gyro's which power Segways and those are well proven. A little tilt and you are off and running. Yet they are not used for power generation. Why ?
I think that is what is important. Not what can be done on a small scale but on something that can generate megawatts. If a free energy
device is not capable of that small feat, then it is interesting.
johnny874
Quote from: sm0ky2 on April 14, 2012, 03:06:24 PM
I believe that IS the point.  If you built a feedback system and looped this thing, that in and of itself would "prove" overunity. Thats the only solution to end this madness, look how much has been posted since this mess started.
When, if you go back, myself and several other engineers presented mathematically where all of the energy is going to, during each stage of the oscillations, shortly after this nonsense began. Proving mathematically, that this system is not OU. But rather, a very efficient method of transfering mechanical energy.
  sm0ky2,
I have posted an expalnation of a feed back loop system. For some reason a plausible explanation is ignored.
Is basic leverage that difficult to understand ? Any more, I will have to belive this is so. If it were something complex,
then everyone would be up on it. If the weight is supported by a lever when it is at the 4 position, it's weight would not be on the pendulum centered at the 10 position.
This would give the counter weight at the opposing 10 position 2 1/2 times the force. Easy enough to leverage the pendulum's weight a little higher than necessary to maintain it's swing.
Sorry, but do need to wonder what you guys are on about for all of these pages.
.(http://www.overunity.com/12247/pendulum-shift/dlattach/attach/98698/image//)
edited to add; as he posts his patents, could be just as the people in here, if he can't claim the improvement as his own, not interested.
he could be more into self promotion. I did send him Tom's (webby1) idea and heard nothing.
