ltseung888
 Let me summarize what I have posted so far:
1. The Milkovic 2SO can lead-out gravitational energy.
2. The Modified Milkovic 2SO with Unbalanced Wheel can lead-out gravitational energy more efficiently.
3. The leading-out of Gravitation Energy occurs at the pulse-pushing and at the highest velocity position.
4. The Peru Energy Multiplier is effectively a pulsed unbalanced wheel.  Gravitational Energy is lead-out or brought-in the system during the friction pulse.
5. Experimentally, the device described in point 2 appears to be more efficient.
The best experimental steps recommended by me are:
1.     Build the Modified Milkovic 2SO with a Bicycle Wheel as the Unbalanced Wheel.  Tune or adjust the various parameters to get a feel of the technology.  These parameters include W1, W2,  L1,  L2, rotational speed (by hand).  Make sure that W2 is iron but not a magnet.
2.    Build another prototype replacing W1 with a crankshaft to get rotational motion of Wheel W3.
3.    Put a loose belt or chain to feedback from W3 to the unbalanced wheel and achieve a "forever running" Bessler Wheel.  Show this prototype to the World (and claim the overunity prize.)
4.    Build another prototype with a Generator turned by W3.  Use the electricity generated to pulse an electromagnet to attract W2 to keep the rotation of the unbalanced Wheel.
5.    Improve the design to provide more power.  The improvement may be multiple unbalanced wheel, shorter or more powerful pulses, etc.
6.    After you become an expert in the "2SO Generator", produce products to harness Gravitational Energy to benefit the World.  If you want to continue research - do the Energy Multiplier and/or vary the magnetic fields.  Compete with the USA and Chinese Military on the 225 HP Pulse Motor?  More posts on those later.
Divine Revelation.
ltseung888
 Simplified explanation of F.M.CHALKALIS ENERGY MULTIPLIER
1.    Input is via Friction. Pulse is achieved via partially grooved axle.
2.    The 360 degree rotated pendulum or Unbalanced Wheel Leads-out gravitational energy.
3.    The lead-out energy shows itself as increased rotational speed and/or torque available.
4.    The Output Energy can be extracted via tension belt or something similar.
5.    The Pulse Mechanism is clearly visible.  There is no up and down lever motion.
I believe the Bessler Wheel type device shown on reply 2222 is more efficient.  It gets electrical power (converts gravitational energy into electrical energy) in a simple fashion.
ltseung888
The full secret of the 225 HP Pulse Motor
1.    We know that we can lead-out gravitational energy.  We looked at such an open secret and did not see for centuries.
2.    We know that a "Pulse System" similar to Milkovic 2SO or the Peru Energy Multiplier helps to lead-out or bring-in gravitational energy.
3.    We can produce magnetic fields with permanent magnets.  The simplest illustration is to use an iron bob and place a permanent magnet at the base to increase the effective g.  This experiment was done by Ms. Forever Yuen over 7 years ago.  We can easily redo the experiment again.
4.    The permanent magnet can last for years.  The extra amount of energy obtained is definitely not related to the energy used to create the permanent magnet.
5.    The Lee-Tseung Lead-out Energy Theory assumes that the Electron Cloud Distributions of the components are different and such energy is brought-into the system.  The system exchanges electromagnetic energy with the surrounding.  Using such energy does not violate the Law of Conservation of Energy.
6.    The Tong Wheel (a slice of the 225 HP Pulse Motor?) is an unbalanced wheel with 15 coils on the outside facing 16 rotating magnets on the inside.
7.    The tuning showed possible overunity.  The parameters used in the tuning process include:
a.     Changing the number of coils used as Drive Coils.
b.    Changing the arrangement of such Drive Coils.
c.     Changing the winding and orientation of such Drive Coils.
d.    Changing the number of coils used as Collector Coils.
e.     Changing the arrangement of such Collector Coils.
f.       Changing the winding and orientation of such Collector Coils.
g.     Change the angle and the distance of the Proximity Switch used to switch the Pulsing Current on.  This was a very crude control method.  The 225 HP Pulse Motor used a much more sophisticated technique to control the strength, the duration and direction of the Pulse.
h.    The strength and orientation of the rotating magnets do not need to be identical.  This was the tricky part of the tuning of the Tong Wheel.  The initial design did not allow easy adjustment.  The later model that generated 1 Horse Power  (By Alan Li of Shenzhen) provided such improvement.
i.       When multiple slices are placed side-by-side, the sum of their effect is more than simple addition.  The magnetic fields or the Electron Cloud Distributions are more complex and some resonance type effects can take place.  By resonance effect, I refer to some conditions that showed a sudden pronounced peak.
j.       The exact construction of the 225 HP Pulse Motor is still a closely guarded "national secret".  However, if we accept that gravitational energy can be brought-in to a system continuously, we can see that a Pulse Motor can theoretically bring-in Electron Motion Cloud Energy continuously without violating the Law of Conservation of Energy.
My suggestion to any groups doing the research is to focus on the Milkovic  2SO using an unbalanced wheel first.  I made the mistake of jumping around for 10 years – from getting energy from air, from water, from gravity, from Pulse Motors, from non-moving flux change systems etc.  My personal resources including money and knowledge are obviously limited.
After much praying, I believe the Divine Guidance is for me to focus on helping one or more Groups with the Milkovic 2SO with an unbalanced wheel.  That is guaranteed to provide overunity.
Demonstrate that to the World and encourage all Governments to replicate and invest.  When all nations can see from their own scientists producing devices leading-out or bringing-in gravitational energy via the combination of "a seesaw and a swing", the World will change for the better.
Divine Revelation?
ltseung888
 Can Hong Kong be the Lead-out Energy Mecca of the World?
The youth of Hong Kong is protesting for a "True Democracy".  This movement is different from the violent clashes of the West.  The students are peaceful, disciplined and self-motivated.  They support each other.  The future of Hong Kong is very bright.
Can we educate the Hong Kong Youth with Lead-out Energy while they are in the Streets?  They have access to Internet.  They are willing to talk and listen to strangers and strange ideas.  Lead-out Energy will guarantee them a future for themselves and their off-springs.  They can lead the World in both Super Democracy and Lead-out Energy Technology.  The hold from Businessmen and Bankers is over.  Ideals such fairness, world peace, sharing of ideas and resources will take root.
When the Protest is over, hundreds if not thousands of Hong Kong Students will master the Lead-out Energy concepts and technology.  Is that a Divine Blessing?
ltseung888
 Question:  If I have a balanced vertical Tong Wheel or a Bedini wheel, can I lead-out Gravitational Energy by adding an unbalanced wheel at the axle of the wheel?
Yes.  The reasons are:
1.    At no load, very little energy is needed to rotate the wheel.
2.    If a Pulse is used to maintain the rotation, the pulse can be very short.
3.    If an unbalanced wheel is attached to the axle, it will cause the wheel to have non-uniform rotation.  This is the secret of leading-out gravitational energy.
4.    The bringing-in of gravitational energy shows itself in higher rotational speed, larger torque and even smaller Pulse Power.
5.    If energy were extracted in such a system, the energy is not only from the Pulse but also from the Lead-out Gravitational Energy.
Not discussed yet is the Leading-out of magnetic or electromagnetic energy.  But adding the unbalanced wheel mechanism to the Tong Wheel or the Bedini Wheel will bring-in gravitational energy to make it overunity.  Does anyone want to experiment?
*** A researcher in Hong Kong, Dr. Raymond Ting, will add an unbalanced wheel to his "Ting" Wheel.  His Wheel uses a chain mechanism to rotate a shaft of a small wind turbine system.  Electricity and recharging battery can be from the commercial wind turbine system.  At present, the system cannot fully self recharge.  Adding the unbalanced wheel and some tuning is expected to tip the balance.
*** Hong Kong will be a Mecca for Lead-out Energy Research?
Divine Revelation?
