ltseung888
Quote from: ltseung888 on January 26, 2016, 03:11:46 AMLeading-out gravitational energy
Reference: Rhead100 video 6.  https://www.youtube.com/watch?v=gC6Qlj1Mbo8
1.   At 2:07 time, the 46 pound pendulum was at its maximum height position.  A small push with the fingers lifted the 74 pound weight twice.
2.   Between 2:07 and 3:30, note that the weight was lifted twice with each push from the fingers.
3.   The weight was lifted when the pendulum was at the lowest height position.
4.   That position was the highest velocity position.  The centrifugal force was highest.
5.   Notice that the maximum swing position was hardly changed.
Some possible deductions:
a.   The 74 pound weight was not lifted until the amplitude of the swing was high enough.
b.   The sum of the twice lifted height appeared to be more than the once movement of the fingers.
c.   The potential energy shown by the 74 pound weight was given by the formula mgh where m is mass of the 74 pound weight, g is the gravitational acceleration and h is the total height lifted.
d.   The supplied energy is the force of the push (f) times the finger movement (d) or fd.
e.   It appeared that output energy was more than supplied energy (mgh > fd) between 2:07 and 3:30.  Before 2:07, the supplied energy is used to increase the amplitude of the swing.
Our explanation is that gravitational energy was lead-out or brought-in.  There is no violation of the Law of Conservation of Energy.  That video was an experimental confirmation.
It may be worthwhile to reproduce the Raymond Head setup so that the experiment can be repeated and improved.
Unbalanced chan wheel shows Milkovic 2SO effect...
https://www.youtube.com/watch?v=p4rgLBU34Oo
Balanced chan wheel does not show milkovic 2SO effect...
https://www.youtube.com/watch?v=Kqtp4-X6TGI
turbogt16v
well i have read some comments on you-tube,and they are correct to answer the riddle of the device..
You are not picking up 74 pounds of weight because that weight is counterbalanced by what the pendulum weigh.
its the same misleading effect when you spin a  massive weight on spinning wheel,you only need small force to keep it going, but you always need it
turbogt16v
i really hate this troll tactics on this forum...
I think the device works because it is not full moon,so the  earth gravity is in its highest point,so it will not work with full moon.
ps. if you don't know what to do ,don't do it here
Merg
 It's interesting how easy they start these big pendulums and keep it moving
...and these effects would be much better with the ceramic bearings and flexible (elastic) pendulums.
https://www.youtube.com/watch?v=C_wAPc4GIC8
https://www.youtube.com/watch?v=A9MzYmRFjog
https://www.youtube.com/watch?v=wk3MABMLa0k
