kratkaforma
Large world-famous and recognized companies from India, China and America, folloewd by numerous companies from other countries that have their offices around the world, produce machines, crushers and devices based on a two-stage mechanical oscillator. These are companies operating in Russia, Kazakhstan, South Africa, Indonesia... The mentioned companies are leaders in the production of machines for crushing ores and stones, and his invention is widely used within the new technology project, where foreign companies recognized the importance of Milkovic's invention.
These companies have recognized the value of Milković's invention as a working mechanism with the lowest possible maintenance costs and maximum efficiency, applied it in the design of a new generation of industrial machines and widely sold it around the world.
https://jubegin.de/2009-1520.html
https://www.pasazrozkvet.cz/2474/2021-02-20/Uv7OK2
https://www.gdpau.org/hammer-crusher/47ig5yb6/2020-07-07.html
https://www.ancgroup.pl/16790-Oct-2012.html
https://www.antonfoto4k.pl/14886_two_stage_mill_machinery.html
https://www.manglabros.in/Aug/23072_08
https://klimattworzaludzie.pl/stone/5125.html
http://www.wcbl-warsaw.pl/crusherreferensistone/jfJuC0
https://tanienoclegikielce.com.pl/2016-08-30_1939.html
https://auto-ecole-saint-etienne.fr/fruit/2021-Sep-06-4621/
https://www.alenosorozec.pl/jaw/2458/2021_09_39/
https://diwalkoburger.pl/grind-mill/list-30.html
https://fearlesscities.waw.pl/May/18-24973.html
https://xn--akademiapikarskaams-fgd.pl/2011-4721.html
https://wynajem-jachtu.pl/z5js5o/3644.html
https://www.darmounia.pl/34104/30KHNV3-Jan-1970.html
https://feestdjnik.nl/Granite/707.html
https://labelprinters.pl/slag/2021_4_1899/
https://a2pasdechezmoi.be/16320-Oct-2016.html
https://www.restauracja-marysienka.pl/Sep_21030/2020/
https://www.elpu.pl/13914/crusher.html
https://www.catering-pasjonata.pl/2021-Sep-30/32913.html
https://beero.be/Dec_16+483.html
kolbacict
QuoteWhen added/subtracted the resultant force determines
   which one moves and which one 'braces'
Do both pendulums have to have exactly the same moment of inertia?
This is not easy to do ...
Floor
                    Thanks for the snap shots.
smoky2's comments are spot on.
If the middle pendulum is held stationary, the outer pendulum shaft,
rotates within 4 bearings.
If the outer pendulum is held stationary, the inner pendulum rotates
within two bearings,
If all four bearings are friction equal.
This is still a 2 to 1 friction difference.
Quote from: kolbacict on October 08, 2021, 12:23:19 PM
But isn't that the goal, of the two pendulum design any way ?
Not easy, and can never be perfect.
"Close enough" and one pendulum will start before the other, But also
at the point of one's having achieved a fine balancing of the moments of inertia,
minor friction difference will become the next factor.
Get the moments of inertia closely matched, then gear the two pendulums
together ?
               or
https://overunity.com/1763/12-times-more-output-than-input-dual-mechanical-oscillation-system/msg560162/#msg560162
kolbacict
If the moments of inertia of the suspension and the load can still be calculated.
however the moments of inertia of the stator and rotor with their complex shape are not at all easy to do. Only experimentally select?
But I noticed that if i give short current pulses just from a pulse generator, with a frequency approximately corresponding to the period of oscillations, they swing perfectly together.
What, in fact, is shown in that video. And the system is not even critical to the moment of inertia of the pendulum.But shocks of force can be anywhere in their trajectory. And I wanted it to be at the bottom.
As soon as you install the hall sensor, miracles begin ... :)
Floor
The video shows both pendulums swinging in sync.
Your comments said they one starts before the other.
Do they start off unequally, but then later they fall  into synchronization ?
