lesleyharrell
Quote from: alan on January 14, 2023, 05:11:22 PM
Heya Chet,
I don't know if it is even close to being right, that's why I put in the questionmark.
Tthis was the idea behind my theory:
An equipotential (i.e. "equal potential") is the continuous curve along which every point has at the same potential. As a consequence, it takes no work to move along an equipotential; no forces pull or push in the direction of the equipotential. From this we can conclude that the force has no component along the direction of an equipotential.
https://phys.libretexts.org/Courses/University_of_California_Davis/UCD%3A_Physics_7C_-_General_Physics/10%3A_Electromagnetism/10.1%3A_Fields/10.1.4%3A_Potentials_and_Equipotentials
Hello! Your theory is correct. An equipotential surface is a surface on which all points have the same potential, meaning that no work is required to move an object along that surface. This is because the electric field at any point on an equipotential surface is perpendicular to the surface, and therefore, there is no component of the electric field along the surface that would do work on an object moving along it.
The relationship between electric potential and electric field is given by the equation:
E = -∇V
where E is the electric field, V is the electric potential, and ∇ is the gradient operator. This equation tells us that the electric field is perpendicular to the equipotential surfaces because the gradient of the electric potential is always perpendicular to the surfaces of constant potential.
Therefore, your statement is correct that the force has no component along the direction of an equipotential.
Merg
A new paper focused at alleviating human effort by using oscillating motion of a pendulum:
Design and Analysis of Pendulum Operated Piston Pump
https://www.slideshare.net/arkadutta58/design-and-analysis-of-pendulum-operated-piston-pump
