A fresh look at the Clem motor
Started by aussiebattler, March 18, 2018, 04:34:56 PM
TommeyReed
If you study all the claims of how the Clem Engine worked, no body has ever made a working prototype.
But if you look at physics of whats really going on with cooking oil, high pressure and heat. It is a type of a diesel engine using cooking oil.
You do know a diesel engine will run on cooking oil don't you?
This is how if it was real would have to work in the real world.
The phase change is were the power comes from, not the rotating fluids!
Tom
aussiebattler
Tommy
Basic physics tells us that as pressure of a liquid increases so does it's temperature. Now if you have liquid flowing in tapering chanels while revolving at high speed you will get some very high pressure at the extremities. If you then release that liquid through small orifices you are setting up the "venturi effect" where the liquid will release energy giving up temperature in the process . The energy loss can then be restored by absorbing heat from the atmosphere -even on cold days . The result is no cost of fuel for 24/7 /365 and
suitable for all kinds of applications.
Do you think the oil companies or the wind and solar boys like this one?
AB
TommeyReed
Hi AB,
Again, those who believe they know how the Clem engine worked, is not based on building any prototype as a example; but a theory.
So going back and forth is not going any where, let me ask you how the Clem engine worked?
What experiments do you have to back up your theories?
Tom
mäxchen
Hi,
maybe you find this interessting:
THE CLEM ENGINE AND ITS MICRO-DIESELING PHENOMENON
https://www.academia.edu/81195428/THE_CLEM_ENGINE_PART_1
my small prototype, still under construction
aussiebattler
Good question Tom In fact I am right at the end near to  having an answer for you . Will keep you informed as perhaps you will too
Cheers
AB
