A fresh look at the Clem motor
Started by aussiebattler, March 18, 2018, 04:34:56 PM
TommeyReed
Please keep politics out of this forum!
So, your mathematics is correct?
Have you tested your theory?
Centrifugal force on the weight of fluids is different then having a solid mass at the end of a rotating sphere.
When moving fluid from the center say, 1" diameter 12", it could be any type of impeller design going outward in a rim jet of say .25 will not create enough pressure and flow rate greater then the amount of energy to rotate it.
(24" x pi)/60 =6.28ft, at lets say 1800 rpms you will have a flow rate at 188 ft/sec coming from the 0.25. The amount of pressure thrust is far less energy to keep it spinning.
Take any centrifugal water pump running at 3600 rpms to create 60+ psi no matter what flow rate you want, the energy created wouldn't be enough to create OU.
Here's even a better experiment, take a 4000psi pressure washer  and see if you can generate greater energy output...Try a simple water wheel using 4000psi water jet and see what output you will get, I know most of you would even try to do these experiments because of the flaw in mathematics in the real world.
Too many variables = the unknown!
Unless you have a big phase change in a fluid, the amount of energy generated would not reach OU.
Tom
aussiebattler
What is more important than getting the maths right is to get the physics right firstt,
ab
aussiebattler
Note that the high temperature and pressure only occur at the inlet to the restriction
