r2fpl
Quote from: listener191 on April 10, 2018, 11:55:36 AM
Just like my rotor the overlap is a lot more than 6 stator poles, about 11 on this one and about 9 on mine.
Pierre looks like he has a custom rotor, as his covers only 6 stator poles.
They could be trimmed down to 6 poles, but  a bobbin edge would have to be created to hold the windings.
L192
Hi L192,
Maybe it has a core from the welder or sheet metal packaged.
Yes 6 slots size.
T-1000
Quote from: seaad on April 09, 2018, 01:58:34 PM
From Y.T.    https://www.youtube.com/watch?v=cF2MHOouwG8
This video have different magnetic poles arrangement. This time the resulting magnetic polarity will be on 90 degrees from previous setup.
Still interesting to see if he will be able to make proper induction... ;)
Cheers!
Jeg
Quote from: r2fpl on April 10, 2018, 10:35:46 AM
Take it out of the housing and remove the wires.
How did you extract your stator from motor's housing? The outer casing looks like an iron cast.
r2fpl
Quote from: Jeg on April 10, 2018, 03:53:50 PM
Just push under the press or cut.
Next ...answer is: https://www.youtube.com/watch?v=ZgkM3qxPjtw
gotoluc
If anyone thinks this is an easy build you better think again. Winding a stator is only 25% of the job. See below video of my finished product. Testing will begin tomorrow after winding the center core.
Fr. Si quelqu'un pense que c'est une construction facile, il vaut mieux réfléchir à nouveau. L'enroulement d'un stator ne représente que 25% du travail. Voir ci-dessous la vidéo de mon produit fini. Les tests commenceront demain après avoir enroulé le noyau central.
Video: https://youtu.be/m16qvt9-2Kk
