seaad
Quote from: r2fpl on May 16, 2018, 08:29:21 AM
Why no fields in this places ?
You must compare it with the video part 3 or 4 by Pierre
Can you give the time points (about) in these films Thanks. And how to see that flux is missing?
Regards  Arne
r2fpl
Quote from: seaad on May 16, 2018, 11:48:40 AM
Regards  Arne
you can see it almost any time
e.g.13:40 part 3
d3x0r
Quote from: r2fpl on May 16, 2018, 12:09:09 PM
e.g.13:40 part 3
there's also a null on the opposite side... I thought it was only 2 gaps 180 degrees opposed; but I see the other near gap you're mentioning...
weak coils?
The rotor is also in it; is it there, but lost into the pickup?
pmgr
Quote from: Jeg on May 16, 2018, 06:27:47 AM
pmgr
Hi pm.
I just finished my stator build and i measured my coils inductances. It is L=7.52mH per coil. Each coil (22 awg) is of a 22.5m length (73T) and this gives me a 1,1 Ohm resistance. The maximum frequency according the equation is about 25Hz. So i wonder if there is any trick that i can do so to raise the frequency up to 50Hz. Any idea?
Jeg
ps. In resistance calculator i measured just the ohmic resistance and not the reactance of the coil. Reactance at 7,52mH and 50Hz is 2.3 ohms. If i add it with the ohmic resistance then i am again in the right range. But is that a valid consideration?
Hi Jeg,
You should measure the inductance with and without the rotor in place for each coil. You should see an increase in inductance the closer you get to the rotor, typically a factor of 4 compared to the minimum inductance when away from the rotor.
Pierre's relays are running at around 4Hz, so I don't think your numbers are going to be a problem.
PmgR
Jeg
Quote from: pmgr on May 16, 2018, 04:52:15 PM
Hi Jeg,
PmgR
Hi Pm
Thanks for the suggestion. These days i will test the relay boards to take an idea for the consumption current. I'll report my findings as for a reference.
