d3x0r
Quote from: listener192 on May 22, 2018, 06:33:32 PM
The 4 ohm resistor is required if you are using a linear power supply, otherwise the current draw when charging the super caps will be excessive. If I apply 20V from a zero charge starting point, 50A is drawn from my power supply, which is the maximum current limit. It would draw more than that uncontrolled. I don't see that the resistor serves any other purpose.
L192
But it's really between the caps and the coils... once that power supply is disconnected (even momentarily), it's running through the 4ohm resistor still...
pmgr
Quote from: jerdee on May 22, 2018, 06:50:28 PM
Listener et all,
  I can not confirm but strongly suggest that your coil slots have to line up with your rotational fields!  PC uses 36/6 = 6 slots, with 30 poles, you are left with 30/6 = 5 slots per winding.  The biggest issue PC is having is his width of the pure field!  The criss-crossing of the magnetic windings does not allow him much options.  This is why he is building a better device.  This is also why we want as many possible slots divisible by 6 on the ROTOR!  If we had a 60 slots on the same size stator, we can then get 60 slots divisible by 6 equaling 10 slots per coil.  We've now created a wider and smoother area to maintain the PURE field.  With the 30 slot rotor, we are doing the opposite, we are losing resolution, which is not good.  This is why the 36 slot rotor is better than the 30 slot system.  But I still believe we can see this effect for sure even with the 30.  Think of it as a digitally controlled rotational field in increments.  I believe we want the highest amount of increments per PURE field.  With a normal generator, the values are infinite, its analog right?!?!
Again, study generator basics. Every one is only seeing one half of the picture.  Again...the rotational field windings is NOT the only answer!!!  I keep saying this.  There is MORE!!!!!
Also, my original thought of using twice the amount of half bridges to strengthen the field is possibly not good!  You will lose something very important.  So the schematic shown below only shows three active half bridges with three more later in overlap.  So only 6 active at any one point in time.   Just like PC.  With his and your relay system using no double throw you have no choice but to keep 60 relays on your system. Which I believe will be fine enough to study the effect.  You will however lose considerable speed and quality of holding the field in rotation with your relays.  This is his hash he is showing in his scope shot.  With half bridges, you can easily smooth this out with a bypass cap.  This is why half bridges have a considerable advantage.  MUCH higher speeds and controlled overlap of the field at these higher speeds.  Higher speeds are important for this device.
Remember this....the STATOR is what makes the current, not the current into the relays.  Your armature output is only colleting the EMF.  I'm certain of this.  Have you asked yourself why PC uses 25V?  And no, we are not braking lenz law here.
Hope this helps,
Jerdee
Jerdee, your drawing looks correct. Just draw it with relays now instead of H-bridges  ;)
And yes, the more slots you have on your stator, the better. It will generate a smoother transition, so indeed less digital, more analog.
PmgR
jerdee
Again, why is he using ~25V on the rotor.  I'm very certian this is your answer.  If you do not use this on your voltage on your rotor, you will not see the positive effect.  There is more!!!  I awaite your answer.
Jerdee
pmgr
Quote from: jerdee on May 22, 2018, 10:06:41 PM
Jerdee
Jerdee, I think I understand what you are getting at.
The 25V on the supercaps will determine what the maximum voltage generated over the coils can be as the diodes will start conducting when the voltage over the coils goes past 25V. The magnetic coupling between the stator coil and the output coils determines what the voltage at the output coil will be and since the voltage over the stator coils is limited to 25V, the voltage for the output coil is limited as well (in Pierre's case to about 140Vrms without load).
PmgR
jerdee
I'm exhausted for the night, need rest....but you are thinking.  But again...there is more MUCH more...watch the videos in very slow motion..  Spend time learning generator basics.  For example, what types of generators are there?  There are many, but which one fits his device.  What is the piston to his generator?  What is it in your device that is not giving you this piston?  Think simple....don't over complicate.  Its human to over complicate.   Then ask gain, why is he using roughly 25 volts., I won't say how...I think many see this but don't want to say.
Jerdee.
