0 Members and 47 Guests are viewing this topic.
FixedSys
Quote from: listener192 on May 24, 2018, 03:53:41 AM
This applet shows the situation in a three phase induction motor.
http://www.nptel.ac.in/courses/IIT-MADRAS/Electrical_Machines_II/animation/sinwave3-9.htm
Its the traveling wave that drags the rotor around. If this were a 3 phase transformer i.e. a second set of windings, you would have induction due to the traveling wave and induction due to the pulsating wave (the three phase AC).
In the DZ there is a traveling wave but no pulsating component (unless you pulse each coil set  off and on).
L192
OK, so the DZ does have more in common with a generator than a motor. I still can't determine "which one (generator) fits his device" but I'm now thinking he means "fit" in terms of electrical characteristics, not mechanical.
"Piston"; presumably that refers to the transfer of force, the flux in this case. Perhaps the polarity is being manipulated more than is apparent.
d3x0r
Can anyone advise...
Is a winding on a transformer that is open the same as one that is in a complete circuit, except blocked by diodes?
To eliminate the mutual induction on other stator coils I was considering adding diodes to the ground side (or power side) that prevents current in the other coils...
like this Falstad sim kinda  (sorry it's kinda a tangled mess; substituted a tapped transformer and tied existing things to it...
Edit: Sorry didn't check it after pasting in wong mode... should have been condensed like that.
gyulasun
Hi d3X
Please use this link to reduce your very long url link to a small one, this way this page will remain as usual, ok?
https://tinyurl.com/
Gyula
EDIT:  Just have made it for you, this is the link to your Falstad simulation:  https://tinyurl.com/ya9wmepj   Please go back and delete
your original very long link by scrolling horizontally to the very right corner of your above post and click on the Modify icon.
Include this link instead of the long one: https://tinyurl.com/ya9wmepj
To Save your modification, scroll again horizontally to the  right side...  ;)
Jeg
Quote from: d3x0r on May 24, 2018, 05:07:20 AM
Yes, that is the way if you use mosfets. I think that there is no need for this extra diode when using igbt's but i have to recheck it.
regards
listener192
Quote from: r2fpl on May 21, 2018, 02:50:56 PM
Pierre,
I know this secret. I will keep it for myself until others know it or tell it.
One of the films is "visible" this secret. You need to know what to look for and what is missing.
I confirmed it the way you did it :) and now I understand your surprise successfully!
I wonder about the time of work, and probably you too. Maybe you already know it but it's unusual.
Thank You !
Hi r2fpl,
I assume if you know the secret, then you by now should be reproducing the same results on your setup.
Do you have a photo of your test results that show this, or a video?
L192
