wopwops
Hi Luc,
I don't intend this to show up in the thread, but do you think it's possible that Pierre is maliciously and intentionally wasting your time and the time of other researchers??? The goal would be to have people chasing their tails to prevent them from working on something that might actually work.
I've been following your work for many years and appreciate it very much. Thank you.
Kevin
Dog-One
Quote from: wopwops on June 09, 2018, 12:18:40 AM
... do you think it's possible that Pierre is maliciously and intentionally wasting your time and the time of other researchers???
The thought crossed my mind too Luc.  Certainly Pierre understands the best form of "protection" he could possibly get is to have several functioning replications built by third parties out there in the wild.  Unless he is talking about patent protection, in which case he came to the wrong place to begin with.
Of all the people doing this research, I'd really hate to see you get jerked around Luc.  You're the least deserving of this form of treatment.
As I said earlier though, you still have a very viable platform to educate yourself and the rest of us with.  Work with what you have, it's all anyone could possibly ask.
seaad
Quote from: gotoluc on June 08, 2018, 08:25:31 PM
Oui, je suis d'accord que tout est dans le plan, mais pour que ce plan fonctionne dans votre démonstration vidéo, vous auriez besoin de 72 fils provenant de votre stator pour que l'isolation fonctionne avec les relais. À moins que vous ayez les relais d'isolation montés sur le stator lui-même qui n'a clairement pas été fait. Alors, comment pouvez-vous isoler 36 bobines avec seulement 36 fils?
Cordialement
Luc
En. Yes, I agree it's all in the plan but for that plan to work in your video demonstration you would of needed 72 wires coming from your stator for the isolation to work with the relays. Unless you had the isolation relays mounted on the stator itself which was clearly not done. So how can you Isolate 36 coils with only 36 wire?
Luc
One possibility to have "relays" at/ inside  the stator itself is to hide REED-relay tongues iside the stator, driven by the different magnetic fields there.
I'm convinsed that a working OU genny with virtual rotating/ moving fields is possible to konstruct anyhow.
And I think Pierre deserves "protection" if his apparatus really works.
But I also agree to the thought above about "the chasing tail DZ-game".
Regards  Arne
listener192
AC generators, armature reaction:
When an alternator is running at no-load, there will be no current flowing through the armature winding. The flux produced in the air-gap will be only due to the rotor ampere turns. When the alternator is loaded, the three-phase currents will produce a totaling magnetic field in the air-gap. Consequently, the air-gap flux is changed from the no-load condition.
  The effect of armature flux on the flux produced by field ampere turns (i. e., rotor ampere turns) is called armature reaction.
  Two things are worth noting about the armature reaction in an alternator.
  • Firstly, the armature flux and the flux produced by rotor ampere-turns rotate at the same speed (synchronous speed) in the same direction and, therefore, the two fluxes are fixed in space relative to each other.
  • Secondly, the modification of flux in the air-gap due to armature flux depends on the magnitude of stator current and on the power factor of the load. It is the load power factor which determines whether the armature flux distorts, opposes or helps the flux produced by rotor ampere-turns.
Full text:
http://www.studyelectrical.com/2014/09/armature-reaction-in-alternator-ac-generator.html
  • L192
    [/font]
fer123
Follow Pierre advice this video can illuminate somehow. Thanks for your excellent work Luc and Pierre and everybody else working in this project and sheering.
https://www.youtube.com/watch?v=gQyamjPrw-U
