Rene/Meissner EMF Higher Voltage Charger Variant
Started by SkyWatcher123, April 08, 2018, 11:52:40 AM
SkyWatcher123
Hi gyulasun, thanks for the reply and the helpful information.
I found an NTE331 NPN in my salvage stock, it has a much higher current gain. I tested it and did not notice much difference in performance, though i did not remove the prebias connection.
If i remove the prebias and it still oscillates, do you think it will be more efficient.
An observation i just made, using the tv transistor.
I removed the ferrite tube core, which doubled the watts input, so i progressively lowered the input voltage from the boost converter to around 37 volts, while keeping similar input watts as all previous testing.
The efficiency lowered to 64%.
I think with this split negative setup, if we go too low with the current flowing through the coil oscillator and into the charge battery, the battery does not charge as quickly and at such high voltage, the battery load test starts to reduce in duration to 12.5 volts, which is where i end each discharge test.
So, even though the efficiency is higher for the higher voltage circuit, it is not always of benefit with this device arrangement.
The best configuration in my opinion, will be the one that charges the battery with the least input, while the battery recieves this charge with the highest efficiency.
The circuit is flowing .17 amps at the moment, whereas previously, it was using .06 amps at the higher voltage input.
The battery charges better and more efficienctly with a higher current flow.
peace love light
gyulasun
Hi SkyWatcher,
This post will be a long one...  :D   You wrote
"If i remove the prebias and it still oscillates, do you think it will be more efficient."
Yes it will, how much more, this can be estimated only partially because the collector-emitter waveform is
not known: removing just the 23 kOhm, the dissipated power in it could fully be saved. But this surely involves
the readjustment of the 15 kOhm resistor too.  Sometimes a transistor with such low hFE is difficult to use in a
self starting oscillator, higher supply voltage helps on this.
First consider the base current via the 23 kOhm:
(80.2V-12.6V-0.7V) / 23 = 66.9/23 = 2.9 mA  and the dissipation in this resistor is 66.9*2.9 = 194 mW this would not
be consumed from the power supply. Also, the transistor would not have an idle current during the oscillator OFF times,
so this consumption would also be missing.  2.9mA*hFE would be the idle collector current, let's say the hFE would be
8 with your tv transistor, then collector current, Ic would be 2.9*8 = 23.2 mA.
At OFF times the collector emitter DC voltage may be 80.2-12.6=67.6V and with the 23.2 mA collector current, the
dissipation would be 67.6*23.2=1568.3 mW BUT because we do not know the duration of the OFF time during the
periodic oscillations we cannot reduce the 1.5W by the actual duty cycle in this oscillator to get the average dissipation,
the 1.5W dissipation would be correct for a continuous operation, not for an oscillating operation.
So you would need a oscilloscope to see the collector-emitter waveform. Now if I assume the average dissipation were
say 1/10 of 1.5W, then this 150 mW + 194 mW= 344 mW would be saved when you could omit the pre-bias resistor
due to the use of a transistor that has a higher or high hFE value.
To estimate how the saturation voltage for the transistor during the ON times may influence efficiency, we would need
to know the ON time of the oscillator when collector current would flow, this would cause a certain dissipation in the
function of the saturation voltage and of course in the function of the collector current. So again the voltage waveform
across the collector and emitter would be needed.
Ideally, the ON time for the oscillator transistor should be as short as possible. This is because of the value of the
L/R time constant for your coil has 'something' to do with the DC resistance loss of your coil and also with the recovery
loss of capturing the flyback pulses. IT is very good you use multiple wires in parallel for the main coil, this automatically
reduces wire loss.
You would need to know the L inductance of your coil that has the 272 milliOhm resistance. Suppose, for simplicity,
it has 27.2 mH inductance with the ferrite tube cores. This would give an L/R time constant of 0.0272/0.272 = 0.1 sec
i.e 100 ms. What this means and how the ON time could be chosen to this constant to get the smallest coil loss,  please
read member 'verpies' post here:
http://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg352483/topicseen/#msg352483
If you do not understand something with his text, I try to help.
Notice that if you remove the ferrite core from the coil, the inductance goes down hence the L/R also changes to a lower
value too, so that one would have to reconsider the ON time BUT the question is how the ON time can be controlled?
Well, in this circuit, this can hardly be done (to end up with less coil loss) because of the 'rigid' (not readily controllable)
feedback in the oscillator. A good solution would be to use a very low power variable duty cycle oscillator (like a CMOS
555 timer) to drive the base of the transistor and seek for the best efficiency possible.
Needless to say, that even with such duty cycle optimization, one has to face a trade-off because the too short ON time
(that yields less and less loss and involves a decreasing amount of input power) goes together with recovering less and
less captured flyback energy from the coil (smaller input current involves less stored energy in the coil).
In this situation the only means to reduce this trade-off is to increase input supply voltage to increase input power hence
increase the amount of the captured energy too.
What you observed as an increasing efficiency when you increased the supply voltage was very probably due to a near
ideal ON time - coil time constant relation to have a minimal coil loss. This you achieved with increasing the time constant
by reducing the R resistance of the coil i.e. you reduced the denominator in the L/R quotient and you inserted a ferrite core
into the air cored coil, this latter also increased coil time constant.
So if you remove the core, you go towards the higher coil loss possibility, unless you are able to adjust the ON time too to
partially compensate for that.  (In this case you reduce L hence time constant also reduces.)
I agree with your opinion on what the best configuration would be and the thoughts above may help achieve or approach
that.  Probably you would still need the core for the coil but you need to reduce a little the inductance wrt the 80.2V supply
voltage position by using less number of cores and / or inserting them partially and thus reducing supply voltage too.
Or you may find the 170 mA input current for the coil is quasy very good for the charging, then try to stay near to it but
remove some number of turns till you approach similar input current range with the ferrite cores inserted.
(This latter helps increase time constant hence reduce loss provided the ON time remains nearly similar for the cases.)
And try to find a switching transistor having a higher hFE  than the present tv transistor (the ZTX type would be ideal in
this respect, together with its very low saturation voltage).
Gyula
Ed morbus
SkyWatcher123  thanks for sharing
Have you tested with more output diodes
SkyWatcher123
Hi gyulasun, thanks for the in depth response and information, i will try and implement some of that information.
Though the idea of removing the prebias, thinking about it, i'm not sure how it would start oscillating without it, with this circuit design.
The ideal on time information is most helpful, you're probably right, the higher voltage was adjusting that.
As of now, using 37 volt total input at .17 amps, it is charging the battery the fastest for the same input watts as previous higher voltage tests, no ferrite core at the moment.
And i have 56 Kohm resistors in each of the resistor positions, the prebias resistor has .2uF capacitor in parallel and the feedback resistor has .22uF capacitor in parallel.
Hi Ed morbus, thanks for replying.
With the 80 volt input setup, i did try the 2 diodes in series, it raised the input a little and noticed heat in them, could not tell if charging increased much.
With 2 diodes in parallel, input was lower and no noticeable heat in diodes.
What are your thoughts Ed, do you think more diodes in either series or parallel would be of benefit.
peace love light
gyulasun
Hi,
You need not remove the prebias if the oscillator needs it to start with that low hFE tv transistor (I hinted on this problem). And now the 56 kOhm consumes less than the 23 kOhm.
Gyula
