NO FAKE! - NO FAKE ALL MECHANICAL MAGNET OVER UNITY MOTOR
Started by magnetman12003, April 11, 2018, 02:48:23 PM
Belfior
I think he is just taking weight of the rotor by using magnets to repel the disc from the bottom plate
This actually made me re-think my magnet motor to have the shaft vertical and not horizontal. Maybe a bit more friction, but easier to manage
magnetman12003
Gentlemen,
Take a long flat stick and place a Halbach array arm made out of six  1/2 inch cube magnets on the end. Secure it so it does not fly off.   Now get yourself a very large ceramic ring magnet.   About 6 to 8 inches in diameter.  Lower the stick towards the OUTER edge of the magnet until you find where the poles "REPEL".  The Halbach pole that is attracting should be on the ""OUTSIDE"" of the stick. Now twist the stick slowly to about 45 degrees and you will find the magnet arm will not only repel but also slide side ways.  Either clockwise or counterclockwise over the edge face of the RING magnet.   Your choice either direction.
Unless you do this you will never understand where I am coming from.
Low-Q
Quote from: magnetman12003 on April 17, 2018, 06:39:24 PM
Gentlemen,
The reactions was mostly pointed towards the subject "NO FAKE! - NO FAKE  ALL MECHANICAL MAGNET  OVER UNITY MOTOR" when there is no proof what so ever, but instead a small experiment that does not really explains anything, people gets tired, fed up, or what not.
When you turn the stick 45°, you must supply energy to do so. This energy is then transformed into motion of the stick. What you do is essensially changing the polarity a bit so the stick-magnet goes from one direction of force to another direction. You will soon find out that this method will cancel out the input and output energy.[/size]
However, "when" it proves to not work, you have at least gained more experience/learning. Learning by experience is never a bad thing to do. It will help you to avoid the same mistakes again, and then go on with new experiments.
Me, personally, will never give up experimenting with things that physicist says is impossible. Looking at things the engineering way, might some times have a different outcome than looking at things the physics way. I hope you understand that I'm not trying to rip off all the exitements you have inside you. I will rather encourage you to fulfill the experiment as a stand alone experiment without influence by Mr. Hand.
Good luck.
Vidar
magnetman12003
If i hold the stick ""STEADY"" at any 45 degree angle without moving it one bit no matter where i put the array arm on the outer edge of the ring magnet the LIKE polarity lifts off and repels sideways CLOCKWISE OR COUNTERCLOCKWISE ""ALL THE TIME"".  The unused attraction array arm  polarity needs to be kept on the outermost part of the stick during this time.    If you twist and hold the stick in one direction so the array arm is at 45 degrees with respect to the ring magnets outer edge the arm will go clockwise. Or by twisting and holding in the other direction the arm will go counterclockwise.  AND IN BOTH CASES KEEP GOING.  THERE IS NO FINGER PUSHING THE MAGNET ARM ALONG. ONLY THE CONSTANT FLUX OF THE RING MAGNET BELOW IT KEEPS IT MOVING.
Buy the magnets and see for yourself.
FROM WHAT I GATHER THE HALBACH ARRAY ARM HAS A HUGE FLUX BULGE ON ONLY ONE SIDE OF THE
MAGNET AND A NEXT TO NOTHING FLUX BULGE ON THE OTHER SIDE.  SO WHEN THE HUGE BULGE IS PUSHED BY THE SAME LIKE FLUX OF A RING MAGNET BELOW IT IT STANDS TO REASON THAT AT 45 DEGREES THE ARM WILL NOT ONLY REPEL UP AWAY FROM THE RING MAGNET BUT MOVE SIDEWAYS AT THE SAME TIME.  AND KEEP ON MOVING!
Kator01
Sigh...
Mr. Ferko , why do you not show a clear picture of how you arranged your Halbach-Array ?
It made me suspicious when I read : "the unused nothpole".
Please have a look at how the structure of a Halbach Array is. Still pic from a vid on youtube:
https://www.youtube.com/watch?v=uQWHjj6ofwo
Please note ( important ! )  that the Arry is complete after 5 or as shown in this vid after 9 magnets and not with 6.
Your blue marking is confusing.
Can you please clarify ?
Mike
