getting more energy out of AA and AAA batteries
Started by mak27, April 14, 2018, 11:55:13 AM
NerzhDishual
@Mak27
Simple. Worth to be tried, IMO.
Usually, Joules Thieves use only one AA bat.
What would you suggest for one single bat?
Thanks,
Jean
mak27
Jean Thank you your drawing is exactly how I have it set up, however I did not try it with one battery. so I dont know how that would turn out
I believe what is happening, is that once the circuit is closed and the current starts flowing through the leds, the magnets are pulling the extra electrons from the steel
the specific gravity of air is approx..0765 per cubic foot, while steel is490 lbs per cubic foot. that is 6,405 times greater  for steel. while copper is
7,085 times greater
mak27
@ LancaIV the drawing that  Jean did is exactly how I have it setup, I do not know the milliamp draw of the LEDs. At first I monitered the voltage every day the first week it dropped .14 volts, and then it flatlined at 2.58 volts when i saw no difference day after day I started checking once a week and then once a month. at the 12th month it started dropping off in voltage  about .01 per week the last two weeks I could tell if the lights were on    only if it was very dark in the room
mak27
I would also like to add, How can this be considered fraudulent, when I am not asking for money, I am not trying to sell anything. Its just a simple experiment
that I thought would be interesting to share, I thought thats what this forum was for???? sharing Ideas, what do you have to loose hook one up if you dont believe me
and see how long it lasts, and hook up  another one without the magnets. I know that some LEDs consume more current than others, so that would be a factor!
Hello mak27,
the given white LEDs technical numbers are to understand as "physical idea" for comparision,
instead 3,5 V and the different mA current values -light intensivity dependant- each one can dimming
this values for personal interests !
Lightning of white LEDs by 3,5V tension begins with 1 mA current :
3,5 mVA x 9600 h = 33600 mVAh
                                5280 mVAh battery capacity
Using this minimum shows that your device work(-ed)/-s mimimal with a C.O.P. >6
up to the calculated  "159 recharge cycles".
                                          Good result for the beginning
btw,my personal view:          not electrons but "Coulumb"
https://translate.google.com/translate?sl=de&tl=en&js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.ebgymhollabrunn.ac.at%2Fipin%2Fph-quir.htm&edit-text=
Sincerely
             OCWL
p.s.: do not be worry about "unfriendly behaviour" from some(any?) members, after own experiments each of us is later wiser (or not !)
a battery capacity prolongation concept with solarcells :
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=DE&NR=29520064U1&KC=U1&FT=D&ND=3&date=19960201&DB=EPODOC&locale=en_EP#
instead solarcells :
http://www.instructables.com/id/Make-a-Solar-Panel-using-Diodes/
or
https://www.youtube.com/watch?v=526xslmO6Ds
what you are doing is like this- but 24/365 - and an artificial solar ambient
http://www.instructables.com/id/Simple-Solar-Circuits/
effect: simple capacity reconditioning circuit
