0 Members and 67 Guests are viewing this topic.
r2fpl
Understand: this is not about the schema, just about the principle. After these years of searching, it should be clear to everyone why they can not do it.
Don Smith showed the principle and 100% of the device, but he never said anything to make it work.
Example: you have to make a cake; you know all the ingredients because you see them, you know the proportions, you know the temperature, so why do not you go ?! maybe you're using bad ingredients.
Ansis,  much easier :
https://overunity.com/17279/split-flux-transformer/msg529903/#new
Magluvin prototype !
  transversal and longitudinal waves in one MEG !
Inductor : ( Volt - Ampere winding turns coils)  x Inductee : Ampere-"turns" = impuls/-es/ oscillation/-s
         Artificial " Tornado "-seeding and earning ; explanation : Biot-Savart Law
                          and Lord Kelvins Spring/Condensator-Analogon
             https://www.britannica.com/biography/William-Thomson-Baron-Kelvin
                       Melvin Prueitt : M.E.C.H , Motor-Engine-Compressor-Hydraulic in one
                          to    M.E.C.A.E. ,  Magneto-Electric Compressed Air Engine ( Ion-Wind-pressure)
Ansis
Idea is Tone Fork 440Hz.
We make kick and Fork start to resonate.
More kicks, lauder sound.
Thicker Inductor, more Amplification.
Fork=50Hz resonator, Kick=Spark.
Ansis
Inside part of Coil=Resonator must be?
It must be material which "answer" to the kick.
It means Kick - Answer(50Hz Magnetic pulse) e.t.c.
This process must be without saturation, like in Tube Single Ended transformers.
Transformers where is paper between E and I steel plates.
If you remember, 50Hz humm is what we hear when Kapanadze turn ON his device.
