0 Members and 76 Guests are viewing this topic.
stivep
Quote from: ramset on February 15, 2019, 11:38:24 AM
Wesley
Do you have a small Cryogenic Dewar we could borrow for some superconductor experiments at one of the open source Labs in USA  also we still have some iron wire to test for "NMR excess energy testing"at several open source labs.please remove if inappropriate
respectfully
Chet K
Yes I  have whole cryogenic lab.
I have chamber to test  electronic elements  in temperature  4K. ( four degrees of Kelvin)
And Yes You can have Dewar  I should have few of them.
Just tell me when.
Wesley.
stivep
https://teslaresearch.jimdo.com/wardenclyffe-lab-1901-1906/connection-to-earth/proposed-methods-for-terrestrial-resonance/In 1988, PhD James Corum, (one of two brothers) focused interest of the public,  on to his own private  research of Tesla.
QuoteSome harmonic of the fundamental earth resonant frequency—up to approximately 25 – 35 kHz—is used for the oscillator frequency.
In this frequency range the around-the-world propagation efficiency is in the general area between 93 to 87%.
As the frequency is increased above this point, efficiency further decreases.
At 160 kHz the efficiency falls below 10%. [Corum, K. L. and J. F. Corum,
"Nikola Tesla, Lightning Observations and Stationary Waves,"
Proceedings of the 1994 Colorado Springs Tesla Symposium, 1994, Appendix II, "The Zenneck Surface Wave"]
The oscillatory transformer provides the high voltage alternating current needed to periodically charge the transmitter's elevated terminal.
A monochromatic subcarrier signal is then added.
This is in the form of an abrupt lower frequency electrical impulse applied at a rate approaching the fundamental earth resonance frequency.
Higher frequency impulses, above the oscillator frequency are also added at every harmonic of the low frequency subcarrier impulse,
be it the fundamental earth resonance frequency or some lower harmonic of same.
[Corum & Corum] While the following quote refers to the use of an RF alternator in conjunction with a resonance transformer to produce continuous waves,
it appears to be applicable to the excitation of earth resonance modes as well.
Number of inventors added small building  blocks:
https://patents.google.com/patent/US3278937A/en
till scientific crowd  around  was ready for
WAVEGUIDE  and TEM, TE, TM  modes.
https://apps.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf
This PDF explains all possible science  in this area till  year:1966
and is easy to  understand for these who wants to build Kapanadze today.
(Example: http://www.nuenergy.org/uploads/tesla/US645576.pdf
this patent has a lot  to do with that article.)
Simple summary:
1.Kapanadze coil  represents electrically shortened  HV part of Tesla coil transformer.
2.Everything that you do with HV part of regular Tesla   Coil you can  do  with Kapanadze coil.
3.The only difference is that with regular  Tesla coil you need much much more space  all around.
4. TEM  and TE, TM  modes  of transmission / receiving and taping into "reservoir of" energy are  always the same for all of them.
5. Everything including us - we are walking at that interface earth/air ( think and look only at that sticky area.)
a. This area is also   the wall of Schumann waveguide.
b. This area is also   used by Surface Waves.
6. No matter if you sending  energy from A to B using surface wave, or extracting  energy from  Schumann waveguide you always use surface wave for it.
7. Waveguide has finite geometrical dimensions. It can be:
a  piece of pipe,
b  rectangle,
c  dielectric slab
e  HV car wire
f  electrical wire with  insulation
g  Earth/ air/ionosphere XYZ coordinates  are fixed.
    by that: Locally present surface  wave at the interface has finite parameters  to be exactly
    at this place and  at that frequency.
  Kapanadze went much  more  advanced than  that.   Instead of using passive antenna he created active interacting antenna to  stimulate the phenomena of.... of the same as would be achievable  with other methods.
  https://youtu.be/zE4GjB1cWLQ?t=606
Wesley
stivep
PART 2a
Example:
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg474393/#msg474393
When you look at picture below look at conditions required to lunch or receive or tune into surface wave.
1- phase
2- angle of incident
3. polarization
each twist allows you to  tune whole assembly to parameters of interest using  very short electrically piece of wire.
and using active instead of passive structure.
However  ground must be present and some stability  of that circuitry  as well.
Spark gap is only one of many ways to create voltage potential.
That could be enough at the right length to catch energy, but lack of stability did not make it to last long, except  for SR193,
and few others.
Summary:
1.At no point  it is important  how strong is Schumann resonance
Energy fluctuation inside waveguide is seen  only at interface.And only in form of surface wave.
and there is plenty of energy there.
However  Electromagnetic waves  in space can not see each other and can not interact .
Photons have no idea about  other photons.
2.special condition of interface  has unlimited number of users using surface  wave  at the same time.
That means that you can  tune to  nature or someone e.g Zenneck  Wave.
But to do that the  few more parameters  need to  match.
Corum Brothers created polyphase ( multi-phase) signal to make it harder to intercept.
3. All of these  individual surface waves do not see each other, and do not know if there is any  presence of any other  energy in the interface.
4. Tariel Kapanadze  Coil is much more advanced than any Corum Brothers  structure
Wesley
r2fpl
Resonance alone is not enough to sustain the process. This is just a required element. The source must come from passing through another medium.
